0 Members and 809 Guests are viewing this topic.
magpwr
hi everyone,
I have tested the RuslanCircuit in the virtual environment with the frequency generator by the TL494/Signal generator at around 27khz as signal A.
I am sticking with the 74HC14 and 74HC00 to generate a 3-phase signal or NanoSecond Generator  as shown at the bottom left of the circuit diagram.Depending which one you choose to follow.
I have attached 2 mp4 video of circuit in virtual one using 1kohms pot instead of the 22kohms which is located at the 74HC00  just to show the difference."You decide if this is a 3 phase generator or nanosecond generator"
I have use best available component  for this video circuit diagram.
The 22kohms pot for 74HC14 control the position of the signal B and C ( One is inverted)
The 22ohms pot for 74HC00 control the duty cycle of the signal B and C to as low as nanosecond
This nanosecond generator  is functioning as per my expection
."Thanks to Ruslan"
Please refer to my most recent edited ver 2.0 posting for the full circuit diagram which i have uploaded couple of hours ago.
At this point i unable to spot any errors in the edited circuit.
I will proceed building the buffer stage,using mosfet in virtual in order to test if there is any more possible flaws or intentionally created problems. :D
I don't know what is wrong with all the delivery related to Don Smith pending items seems to be long delay maybe due to Year end season.Another weekend nearly burned.
corry
Quote from: Jeg on September 26, 2014, 03:29:21 PM
Corry, is it possible to say some things more? F.e. why to divide my cable meters by two and then to multiply it by four? What is the theory behind this?
Thanks
Because the true "resonant bifilar coil" is the first and the second layer (see TESLA PATENT 512.340).
These first two layers are in fact about half the length of the entire coil Tesla/Kapanadze.  ;D
MenofFather
"Where is the synchronization connection from the TL494 generator to circuit to provide signal for 2SC5200."
I bealive, that Ruslan divice not have synchronisation.  :)
magpwr
Quote from: MenofFather on September 27, 2014, 02:34:19 AM
hi MenofFather,
I have attached this circuit to show you the synchronisation i am talking about is getting the nano pulse to appear in the middle of the peak waveform.
The older circuit i do admit there is no real synchronisation at all.
You are right if you are referring to the older circuit which i have attached to show there is no interface to sync the signal betwen 74HC00 and TL494.It's purely base on adjustment.Which means it is set and forget.
With all the recent knowledge on Tesla coil tuning.It depends on you which method is better from here on.
I'm about to start creating a tesla coil and later combine with the nanosecond generator using around 150volts dc just to see if there is any interesting effect.
I will be observing for Amps via clamp meter on the cable which is connected to Earth.Primary objective to observe for any current flow.
I do not own a clamp meter yet.Hint- all electronic gadget i have bought is based on reviews or benchmark test.I don't rely on price.
May i ask you MenofFather what direction you are planning to take to built a device.
