0 Members and 434 Guests are viewing this topic.
magpwr
Quote from: Jeg on September 27, 2014, 09:19:18 AM
And something else. My Yoke core with 24V input, 6+6 turns primary and 28Turns secondary gives less than 200V pk-pk. How ruslan with the same turns and 12V input reach 220V?
hi Jeg,
The rectified output from Yoke/toroid core using 4xfast diode to form full-bridge(Don't use typical full bridge as these are design for low frequency 50/60hz)  and high voltage capacitor around 300volts connected with a high voltage decoupling ceramic capacitor would produce around 150volts as long it's more than 100volts eg:120volts at least you should be ok.
If you read up the pdf which i have it google translated base on Akula Tesla coil tuning.He mentioned somewhere about lowest voltage for nanopulser to use is 100volts.
I have fully assembled the circuit in virtual environment and found that there is one more intentional mistake made which the 2 resistor value(840 Ohms,20kohms)
located at IRF4905 were intentionally swapped. This IRF4905 can never be turned on with original resistor layout unless you swap both resistors 20k->840,840->20k. :D
I will upload the final edit version 3.0 to this circuit along with full component assembly in virtual and final explanation and video.
The nanopulse now perfectly tallies with Ruslan drawing.
Jeg
Quote from: MenofFather on September 26, 2014, 02:09:07 PM
Ruslan say, that output coil frenquency is 4.6 megaherc and that kacher work on trith (3) harmonic.
4.6MHz/2/2/2/2/2/2/2/2=17.9KHz
Mag for 220V how many turns approximately you think i need for my yoke secondary?
magpwr
Quote from: Jeg on September 27, 2014, 10:02:27 AM
hi Jeg,
Why 220volts when you need only to create 150volts dc.By the way the high frequency transistor 2SC5200 base in datasheet max voltage is 250volts.
I am unable to advise  if you don't wish to follow circuit spec.
I prefer to do things on "as is basis" and not on "what if basis"
Jeg
Quote from: magpwr on September 27, 2014, 10:13:34 AM
hi Jeg,
Sorry man we are talking about different things. By the way, check the snuber diode at the circuit that you attached. It is wrong oriented. It has to have face down for charging the capacitor without resistance. Personally i am almost sure that if you go with katcher you don't need this so called snuber at all as you want a clear sinus wave from yoke.. This 'snuber' is for loading the low frequency signal with higher frequency pulses and initial is designed for using it without katcher..
magpwr
Quote from: Jeg on September 27, 2014, 10:21:50 AM
hi Jeg,
Thanks for advising about the snuber portion.I guess this flaw can only be discovered and fixed through actual experiment with Yoke core.There are certain limits in virtual environment.
