0 Members and 715 Guests are viewing this topic.
magpwr
hi everyone,
I have attached the latest  edited version 3.0 of the circuit diagram in rar file after discovering and fixing a intentionally created bug in the nanopulser section based on the Ruslan circuit.
The latest bug was discovered at IRF4905 which the resistors 840,20kohms were intentionally swapped.This prevents the IRF4905  from switching on which the function is to provide a positive bias(11.6volts) via 1.2kohms resistor to turn on high frequency transistor KT805A or 2SC5200.
Side Note-
The Ruslan circuit which i was analyzing which the bottom of Tesla coil is also connected to the transistor base.
Kinda reminded me of the circuit in video i previously made for wireless tesla transmitter
which the transistor is positive biased to trigger switching upon power on.http://www.youtube.com/watch?v=RiEDIx4Qi8o
I have also attached a video of the assembled circuit in virtual environment in action.
This nanosecond pulse at Channel D(Green) in virtual scope now looks very similar to Ruslan drawing related to nanosecond pulse.
R9 can be changed to 1kohms pot .This makes tuning easy as tested in virtual.
Jeg
Quote from: magpwr on September 27, 2014, 11:17:52 AM
hi Jeg,
I guess this flaw can only be discovered and fixed through actual experiment with Yoke core.There are certain limits in virtual environment.
I agree with you..
Take a look what you can do just with snuber. If you add pulses from katcher then you are going to produce unwanted beats.
MenofFather
Quote from: Jeg on September 27, 2014, 09:19:18 AM
And something else. My Yoke core with 24V input, 6+6 turns primary and 28Turns secondary gives less than 200V pk-pk with nothing else connected at it. When i connect it to the bifi is not more than 50V pk-pk.
How ruslan with the same turns and 12V input reach 220V?
From inductor maked curent plus that voltage and you get 220 volts. For inductor he say 3-4 turns. Here is series resonance, so on bifiliar inductor coil you get not 6 volts, but 150-100 volts. 150+50=200. That is enought for power suplly to made selfrunning. Wery simple.
MenofFather
Quote from: Jeg on September 27, 2014, 09:30:17 AM
Menof..
At yours schematic, bifi coil is different than ruslan shows. Ruslan's drawing show a bifi wounded as exactly the blue aquarium coil, and at your schematic every layer cancels the other. The overall inductance is very different to those two coils. Your way of winding will give not more than 30uH, and blue coil is over 100uH. Why is that difference in those two schematics?
In my schematic layer not cansels each other. You not properly read schematic. You can read about dots in woundings and that they mean and if you understand how they say in that side need wound, then you understand, that in my schematic dots is properly puted.
Jeg
Quote from: MenofFather on September 27, 2014, 11:53:20 AM
Got it Menof thanks! I feel that we already have everything we need to do the job.
