0 Members and 825 Guests are viewing this topic.
GeoFusion
One wire,   back and forward when coiling the layers as this tk coil.
Hoppy
Quote from: GeoFusion on September 27, 2014, 01:05:47 PM
Kapanadze used stripped co-ax for this coil. Is this important??
GeoFusion
Yes that is what Kapanadze used in most ( not all ) of his devices.
But we won't use Coax now.
no coax.
Use good stranded wire with good core. @2.5mm, 3mm should be great. or 4mm is optional would be good to.
Hmm Will somehow show how the coil is wound 1 time one wire.
Ruslan's and Akula's are pure stranded ... except for the Dally shorted- Coax device.
The entire Setup is all stranded except for the kacher.
have been a  Long time on Realstrannik.ru
http://realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=1656
magpwr , Hi.
RuslanCircuitEditedVer2 is interesting.
good luck with the modified  RuslanCircuitEditedVer2 schematic, although Ruslan did not make the original of this schematic at all, it was another guy.
but would be interested to see how it works.
MenofFather
Quote from: Jeg on September 27, 2014, 12:01:57 PM
Got it Menof thanks! I feel that we already have everything we need to do the job.
I also that think.
magpwr
Quote from: GeoFusion on September 27, 2014, 03:17:53 PM
no coax.
magpwr , Hi.
hi Geofusion,
Glad to see you back.
The nanogenerator section tallies with Akula circuit which i use to attached together rar file in edited ver1.0 and ver 2.0 in older posting.The bug was intentionally created in the Akula circuit.
This to deter anyone whom just take circuit and replicate.
Please do refer to the latest edited circuit  version 3.0 which i have posted\attached few hours back.Total intentional created bug detected in circuit was more than "5".
The only stage which i have not tested to confirm is the snubber network to drive yoke/toroid.This was mentioned by jeg.
Later in the day if got the time i will upload my Don Smith China replication "primary driver stage" which is driven by 12volts battery to variable dc high voltage 500....1600volts generator together with my
7KV high frequency switcher is comprised of 1200volts x 6 IGBT Cree to power the 5 turns coil/capacitor.
I am surprised that it can generate spark via surge-arrester below 1000volts dc from Variable DC Hv generator which trigger some kind of chain reaction which consume <2Amp to power pri induction coil which is connected to 40KV probe to oscilloscope.
I have finally figured out what was high Q high voltage capacitor used in the original setup.
I am without B&W coil and hv capacitor for secondary stage at the moment.
