0 Members and 776 Guests are viewing this topic.
magpwr
hi everyone,
I have detected 2 more bugs in the circuit.I have attached version 4.0 fix.
This time this time it is located at IGBT driver UCC37321P.This driver is a inverting version this is wrong.
Both I/C should be non-inverting UCC37322P(15volts) or alternate version TC4422 which can support higher voltage 18volts.But If someone is using 24volts to drive yoke/toriod then MC34063 is no longer needed.But need to take care of the maximum voltage allowed by both IGBT driver version which need to be connected to suitable voltage regulator eg:7815 or 7818.
Lastly the both inputs of UCC Driver at pin 2 was technically shorted to the ground using 100ohms resistors .Both 100 resistors to be removed.
Unverified and untested area in circuit portion.
Since i have ever worked with TL494 for PWM generator.I am unable to advise at this moment if there is any issue at this area.
PWM generator issue  base on TL494 can be easily solved by referring to other circuits.
Only pending items is the snubber components which can be fixed through experiment.
The on/off circuit section located at top left section of circuit presentation is purely optional which can be removed to save time.
I have not checked this section if this is functional in virtual.
To wrap it up the original circuit was merely presented as a demonstration to understand the concept maybe but without the intention for anyone to replicate.
At this point i have discovered and fixed around "7" intentionally created problem by the creator.
I am now very confident there is only 2 portion in the "circuit" to be verified TL494 section and snubber.
The nanopulser section is already completed and tested in virtual.
Tips for the day for any experienced circuit builder-
33seconds into this video do look at the simple snubber ceramic capacitor likely 1000volts or 2000volts likely around 2.2nf.This is the only one used to protect igbt driver for yoke.
I did spot a another circuit in this video which obviously using MC34063 to boost voltage either for TC4422 or UCC37322P
Ruslan Kulabuhov  - Обсуждение СЕ генератора
http://www.youtube.com/watch?v=7_z_cqygQK8
Ruslan Kulabuhov -
Генератор Свободной энергии(в открытом виде)
http://www.youtube.com/watch?v=kAz0wqQD4Zw
At 12:53 min observe it is a large toroid used instead of yoke.This is good news for us.
13:08min  into this video-
Пояснение по работе Генератора СЕ
http://www.youtube.com/watch?v=xOc-7EXMvNc
Bottom of tesla coil is going into large transistor 2SC5200 via blue cable.
The positive line is going into the box with 2 big capacitor likely 350volts or 400volts rated.
The negative of transistor is also connected to green strip cable which is linked to connector beneath the primary tesla coil.From there the long white cable which is mounted onto table is also leading to Earth.
The primary tesla coil 2 connection red and blue is going to transistor.There is a mini pot to provide the postive bias for transistor.
The only thing i was unable to spot is a another cable which is likely or might be hidden to provide the nanosecond pulse to the base of the  transistor.
Dave45
@Nick
Hey Nick are you still playing with the mazzilli
This may be of use http://www.intalek.com/Index/Projects/Patents/DE3024814.pdf
I bet the mazzilli would run this.
NickZ
  Dave:
  Yes, I am working on a new Mazilli/yoke to the Akula/air-coil crt now.
   I've seen the posted information above, but that is not a free energy generator.
Which is the goal, and not just a more efficient generator that still requires a power source.
  I'm still trying to understand what it is about the Ruslan crt that allows it to self run. Like, just how the feed back path works, and if it can be made to work without the nanosecond modulator, even if the output is lower, but still self running.
  I would rather buy the modulator circuit(s), as obtaining all the needed parts for it is not easy for me , here.
  Ruslan's hand drawn diagram does not include or show the feed back path. Without this loop the device will NOT self run.
MenofFather's Ruslan diagram includes the 12v feed back path, backward connected from the inverters 220v down to 12v, then back to the input source.
This is what can allow the crt to self run, once started from an external source.
I don't understand why Ruslan did not include it in his drawing.
  Is this backward connected inverter able to provide the 12v input when connected up this way???
Hoppy
Quote from: NickZ on September 28, 2014, 10:16:39 AM
Nick,
Its not a backward connected inverter, just a switched-mode power supply (SMPS).
GeoFusion
Ruslan just wanted to show what is of most important to make the device work using the coils and caps and reaching resonance.
Eventually when it works just apply the inverter from 220~115V to  12V  and 10Amps or greater to the output to run the circuits.
Use creativity, use the mind and experiment, try out.
Not so difficult when applying a feed back, only need to know how much the circuits consume, know how much watts you need in 12v area or 24V setup, all will depend how Each one does it.
most of time is good to place caps befor inverter ( will act as filter ) to keep a good charge to the power supply and give the necessary 12V output.
   magpwr:
Sure man, I will look to your version 3.0. of the schematic.
Btw the snubber is simply protection  when a short occurs at the output of the yoke, that is what I have experienced.  It's protection, you guyz must have
posted something about this already for sure.
Yes looking forward to that one too. Don Smith China replication.
cheers
