0 Members and 749 Guests are viewing this topic.
Void
Quote from: Jeg on September 29, 2014, 02:15:22 AM
We have already covered this but it is a long time ago. These diodes and caps that you are referring about make demodulation of the mixed signal. (See am demodulation with diode and cap...).
What I would like to ask is if this 220v ac to 12v dc converter is able to handle a higher frequency than 50Hz at the input, cause its input frequency is at KHz range.
Hi Jeg. It could be 'demodulation' (a low pass filter), but I personally have not seen any scope shots from Akula or Ruslan
that would confirm that such low pass filtering is necessary. That may be the case however.
That's a good point about the frequency of the output waveform.  Some power supplies
might handle higher frequencies OK, but others might not work well at all very much above 50/60 Hz.
It would depend on the power supply. Off hand I don't know how a typical switching power supply might
perform at say 17 KHz input as compared to 50/60 Hz. I have never tried it. That is another reason
to consider rectifying to DC at the output however, like Ruslan showed in his recent hand drawn schematic.
I hadn't thought about that. Maybe someone out there has done some experimenting with this already.
I am more concerned about trying to get a circuit to produce over unity right now, and I will
worry about looping back the power only if over unity can be achieved. :) If a person can get to there,
then just viewing the output waveform on a scope should tell you what you will need to know to decide
how to loop back the output.
I think this is the power supply that Ruslan has been using in recent videos:
Model: S-120-12
Input: 120/240 VAC
Output: 12VDC, rated at 10 Amps max output current
Like this one on Ebay for example:
http://www.ebay.com/itm/AC-110-220V-DC-12V-10A-Switch-Power-Supply-Driver-for-LED-Strip-Light-S-120-12-/311100900630
All the best...
magpwr
Hi everyone,
There may or may not be a small possibility the switch mode power supply is modified to support higher frequency.
Just take a look at a various switch mode power supply circuit diagram as found via internet.
It's basically taking a/c mains and converting to dc before being stepped via tranformer which is switching at higher freq than mains.I mean around 200volts for 110volts or 400volts dc from 230volts at the first stage for switch mode supply.
The only possible/logical modification i know is to replace full bridge rectifier with 4 fast response diodes.Full bridge rectifier if you take a look at it's spec in datasheet is intended to be used in mains provided frequency 50/60hz.
If you want to experiment to confirm do try to see if slow bridge diodes can provide similar amerage in high freq in example yoke or toroid output.
Jeg
Dear Team-partners!
I hope that someone already have done this so to inform us. If indeed needs 50hz, then there is an easier way to do it than to make modification at diodes side.
I already have used this technique in many cases and works fine. Just supply all the dc voltages by first converting 220v ac to 24 or 48 ac, and then rectify it through a bridge with no smoothing caps. Those 100hz dc pulses first of all synchronizes all the stages (katcher&LF) and at the end after the final demodulation we have 50hz at 220v. When you 'll be there and need further explanation just ask for it.
Void
Quote from: Jeg on September 29, 2014, 06:09:33 AM
Dear Team-partners!
Hi Jeg. Ok, I set up a quick test with a power fullwave bridge rectifier module,
using a function generator set to 20Vpp into the FWBR, and from there to a 50 ohm load.
Exact results will depend on the actual FWBR module or diodes that are being used
in any given switching power supply, but these test results should give an idea.
At 17 kHz and 37 kHz, there is a negative portion to the output of the power FWBR.
This might cause problems for the switching power supply, including possible failure of
the electrolytic filter capacitors after a while at the power supply input. There is distortion on
the rectified waveforms at 17 kHz and 37 kHz, and there is some loss of peak signal level,
which is not surprising using a FWBR designed for use at 60 Hz.
Based on these test results, it would probably be a good idea to change the FWBR
or rectifying diodes at the input of the switching power supply if possible (as Magpwr suggested) to use fast or
ultrafast power diodes, or to do as Ruslan did and convert to DC using fast power diodes (12R06) right at the
output of the bifilar coil. There are of course probably other options as you suggested such as stepping down the
output voltage to the desired voltage before rectifying to DC to save having to use a power supply.
All the best.
Tested at 60 Hz, 17 kHz, and 37 kHz
starcruiser
If you are replacing the input stage FWBR with fast diodes, please check the following components as they are probably designed to block unwanted noise, i.e. filter stage that might need adjustment (i.e. diff cap and/or inductor).
Regards,
Carl
