0 Members and 56 Guests are viewing this topic.
Hoppy
Quote from: starcruiser on September 29, 2014, 02:42:25 PM
I think you mean 27mhz Hoppy. This is 27khz
I think the citizen band caving frequency was / is 27KHz. Any caving done in Russia.  ;)
starcruiser
I am curious as to the choice of frequencies myself. The 1.8mhz area was used for Lorain C in the us upto the 70's / 80's then decommissioned. is something like this still active in these other countries? loads of power being dumped into this band 1.8mhz, could this be what they are tapping without knowing it or ????
Look into hetrodyn receivers, this would be similar IMO, the mixing in the air core coil with a high and low frequency, power is tapped using sympathetic oscillation that matches the transmitter.
Regards,
Carl
starcruiser
I am not trying to say this is the case but we need to understand how this actually functions, thus if this is the case Tapping power from a high power xmitter, then the system will not function in the US or any place without that energy in the band. we could look at re-tuning to a new Freq with power to see if that is the case if the 1.8mhz or similar does not work.
Regards,
Carl
Hoppy
Quote from: starcruiser on September 29, 2014, 03:10:27 PM
I am curious as to the choice of frequencies myself. The 1.8mhz area was used for Lorain C in the us upto the 70's / 80's then decommissioned. is something like this still active in these other countries? loads of power being dumped into this band 1.8mhz, could this be what they are tapping without knowing it or ??? ?
As I understand, the 1.8MHz top band was extensively used in Russia and is still popular. There must still be many high powered TX units still available at low cost. I dismissed this approach when I first started to see Kapa type devices but I'm now beginning to think that this needs further investigation. I'm not an amateur radio operator myself or very knowledgeable on radio but it does seem feasible to me that these devices could be tuned into nearby powerful TX's, maybe using Kapa earth leads as ground planes / antenna.
starcruiser
Quote from: Hoppy on September 29, 2014, 03:21:05 PM
As I understand, the 1.8MHz top band was extensively used in Russia and is still popular. There must still be many high powered TX units still available at low cost. I dismissed this approach when I first started to see Kapa type devices but I'm now beginning to think that this needs further investigation. I'm not an amateur radio operator myself or very knowledgeable on radio but it does seem feasible to me that these devices could be tuned into nearby powerful TX's, maybe using Kapa earth leads as ground planes / anternna.
My thoughts, as I stated I want to understand the operation, even if it is such a device (receiver) then we can tap other sources by retuning.
That is why I wonder if Akula is aware of this potential source of energy. When he went to Germany was the signal source too weak or that country does not use that band any longer like the US gov doesn't as they changed the tech they use. When his device failed to function as expected.
Regards,
Carl
