0 Members and 268 Guests are viewing this topic.
T-1000
Quote from: itsu on October 01, 2014, 07:37:04 AM
Hi Jeg,   yes i did, but its not that simple as you say.
The L3 (2x 25 turns) bifi self resonates at 1790KHz (with only the scope probe capacitance)
The L1 (2x 48, 2x 24, 2x 12 turns) bifi coil self resonates at 1950KHz (with only the scope probe capacitance), but it has more (lower amplitude) resonant points higher up.
But when using the 0.47uF capacitor on L3 (series or parallel), it resonates at 26.5KHz, so take your pick.
Regards Itsu
The Ruslan's "grenade" kapanadze style coil (48T+24T+12T) was resonating on 4.8MHz, so his Tesla katcher was tuned to 1/3rd - 1.6MHz and was switched on and off for spikes on 15-27kHz repeating positive only cycles in induction circuit where the low frequency was resonant harmonics of 4.8MHz as well.
Cheers!
Jeg
Quote from: mrzlica on October 01, 2014, 08:06:51 AM
Hi,
just for the info it is very close to 27khz
http://www.sbresearchgroup.eu/index.php/en/articoli-in-inglese/169-electromagnetic-mechanism-of-the-ultrasound-on-the-bosnian-pyramid-of-the-sun-visocica-hill
regards, m
Exactly this is what I meant. As you see the higher power is around 5Khz. Before I get involved to the over-unity area I used to build simple vlf receivers which were using this strong telluric emissions to locate secondary em emissions from buried metals. 5kz is a universal emission all over the planet. 27khz is a strong emission in Balkans coming from north to south. But there are many more frequencies that someone can use. You need just the equipment I described before to find the strongest emissions.
Itsu, My personal opinion is that the appropriate  calculations have to start from the low KHz frequency that you want to tap on. When you decide you have to find the harmonic which lies between some 5 to 11Mhz for convenient bifi multilayer coil construction. But lets assume that we blindly follow the specs of ruslan. You don't care so much about the resonance of the two layer total 50turns coil because you anyway force it to vibrate at this low frequency KHz range. You care to tune the 28 turns circuit including the multilayered bifi output coil, at this kz range. And this is not happening at those circuits that are published like bruto's or ruslan's. Without resonance there at the KHz range you will get nothing.
Mag, I was expecting to recognize Don's methodology at ruslan's output. The circuit just lacks the capacitor in parallel to the 28 turns coil and bifi! Yes I am aware of these Tesla quotes as I have read this interview more than 3 times. And every time I do it I see something new! Anyway, I am still on the tuning process, experimenting and enjoying my cigarette with many caps of coffee per day! Yesterday all day I was trying to tune this 28turns circuit with no results. Today I am going to proceed ala don smith. Good  luck and happy experimenting!
Void
For those whose speak Russian, do you know which specific coil on his device Ruslan is referring to when
he uses the term 'съемной катушки'. In English this translates as 'removable' or 'detachable' coil.
Which specific coil or winding is Ruslan referring to when he uses this term?
All the best...
Jeg
Quote from: T-1000 on October 01, 2014, 08:34:44 AM
Cheers!
Normally you don't need to synchronize the pulse as to give the high frequency only at the peak of the low frequency. Do you remember the link that you posted some pages back with these two Tesla coils firing at different frequencies producing fireballs? Check the common primary that triggers them at a low bps frequency. Once primary fires, both secondaries continually fires at different rates. Just need to be harmonics of the same fundamental.
Hoppy
Quote from: Jeg on October 01, 2014, 06:43:19 AM
@Hoppy, starcruser
Search about telluric currents and their dynamics in different places on the planet. Don Smith had published a map on this matter. The most appropriate is to use a broadband VLF receiver (acoustic band) and a spectrum analyser to find which frequencies are stronger in our neighborhood. And then tap on it.
Hummm, I'm not at all convinced on the telluric currents hypothesis for the Kapa devices. You will recall that a.king21 was adamant that his 'team' witnessed disconnection of the earth wire and Kapaanadze's Aqua2 device continued to operate. The crude termination of the earth wire to Rusian's domestic radiator also is far from convincing me that ground currents are instrumental in the operation of these devices.
