0 Members and 715 Guests are viewing this topic.
Jeg
Quote from: Hoppy on October 01, 2014, 10:22:23 AM
Hummm, I'm not at all convinced on the telluric currents hypothesis for the Kapa devices. You will recall that a.king21 was adamant that his 'team' witnessed disconnection of the earth wire and Kapaanadze's Aqua2 device continued to operate. The crude termination of the earth wire to Rusian's domestic radiator also is far from convincing me that ground currents are instrumental in the operation of these devices.
It is a question how that happened. But I am sticked with the elastic medium Tesla's proposal which say that em waves up to some 20-70khz are trapped inside the earth until someone to tap on them.
Void
Quote from: itsu on October 01, 2014, 07:37:04 AM
The L1 (2x 48, 2x 24, 2x 12 turns) bifi coil self resonates at 1950KHz (with only the scope probe capacitance), but it has more (lower amplitude) resonant points higher up.
Hi Itsu. I am not sure if you mentioned it already or not, but did you measure the
inductance of your multi-layer bifilar coil? if so, what is the measured inductance?
Did you wind the 2x24 and 2x12 turns layers in the opposite direction to the 2x48 layer?
By any chance did you measure the full length of the wire you used to wind this coil, or
did you just wind it and not measure the full length of the wire?
I am going to wind my bifilar soon, so just wondering how you have done yours.
By the way, your coil assembly is a work or art. Very nice assembly job! :)
All the best.
NickZ
  The first Akula device (750w) did not need to use an earth ground connection, but he said that it ran cooler (possibly) and with higher output when using his earth ground connection.
  Which should also prove to some degree that the energy is NOT coming from the ground. As there are at least two self running devices that ran without an earth ground. But, not as well, possibly.
  So, the Ruslan hand drawn diagram (also Brutto's) does not have a nano pulser modulator crt for the Kacher oscillator???  Much simpler...?
  The 48,48  24,24 12,12 that is being mentioned is not bifilar wound. The 25 turns times 2 coil is the bifilar. But neither Akula nor Ruslan are using 2 times 25 turns, as it looks like they are using only 12,12 turns.
  Both the bifilar and the bigger air core are connected together in both Akula's diagram, as well as Ruslan's diagram. So, there are three different frequencies including the Kacher, heterodyned together to produce the results, all connected to a long earth ground cable.
Hoppy
Quote from: NickZ on October 01, 2014, 11:56:34 AM
  So, this last Ruslan drawn diagram (also Brutto's) does not have a nano pulser modulator crt for the Kacher oscillator?  Much simpler...
Interestingly, it also lacks a Kacher oscillator or spark gap!  ???   So, what is Brutto trying to put over with this schematic?? Possibly that it can be made so simple that you'll laugh  ;D , or maybe its just intended as a diversion.  :-\
GeoFusion
Hi
@Mag
Thank you for posting the Tesla interview and thoughts.
I have somehow read that somewhere last year.
great to see this happing.
On the right path within this forum.
Check this out:
Akula's TT load test and frequency of arc. good material too see.
https://www.youtube.com/watch?v=1Rr-qTvTrdU
https://www.youtube.com/watch?v=uG705Ayant8#t=121
