0 Members and 715 Guests are viewing this topic.
Void
Quote from: Hoppy on October 01, 2014, 12:28:00 PM
Interestingly, it also lacks a Kacher oscillator or spark gap!  ???   So, what is Brutto trying to put over with this schematic?? Possibly that it can be made so simple that you'll laugh  ;D , or maybe its just intended as a diversion.  :-\
Ha ha, easy mate. :) Brutto just redrew Ruslan's hand drawn schematic from Ruslan's video.
Probably for simplicity, the component details on the push pull driver and kacher driver circuits were not included
in Ruslan's drawing, but instead were just shown as blocks. It doesn't mean that those driver circuits are not there. :)
We just don't know all the exact components that Ruslan used since he showed only blocks for those two devices.
It could be Ruslan didn't want to show exact details there, or maybe he felt those circuits are widely known
now, so to save time he just drew blocks for the driver circuits.
All the best...
NickZ
  Hoppy:
  It looks like that are some unnecessary things in the older versions, which are being discarded as they are possibly not needed anymore.
  Also, check my edit to my last previous post.
  Geo: I built a new Mazilli crt to use, instead of the fet protection crt used by Ruslan. This is because I don't see much difference in that part of the induction crt. And since I don't have the nano pulser thingy, I still need to turn the induction crt part using the tuning caps. Or the amplitude is not a good as I had it working previously with my original Mazilli tuned using the capacitors.
Possibly these tuning caps are doing what the frequency adjustment pots are doing in the nano pulser. I tune to maximum output by using these caps.
What do you think?
  Void:  Ruslan has a new circuit, and did not show it in the "blocks".
But, may include it later on in his diagram, when he get the new set up tested and working properly.
  My question is, if this new circuit includes a separate modulator to control the Kacher's duty cycle, and frequency controller. Or not?
d3x0r
re 7414/7400
The high/low on of that system can be reversed by reversing the connection on the 40/.5 transformer
it's overall an enabled system, that even the chips aren't powered on a low state.
that provides the pull-up basis for the kacher... otherwise it's low-normal, and not conducting.
it looks like the drive kacher would be pulled high during a high on the output.
It operates on one half or the other of the low frequency drive... but again just reverse the connection to the 40 turn coil and it's the other side.
re: removable coil -
think that's the whole coil assembly... the one in this schematic that doesn't have specific turns labeled...
I sometimes think he refers to a specific coil on that... like the extra drive coil on the kapa-coil... but maybe it's the whole assembly.
Hoppy
Quote from: Void on October 01, 2014, 12:37:55 PM
All the best...
I am are referring to Brutto's drawing in post 5436, not his neatly drawn schematic based on Rusian's circuit diagram. The empty blocks  obviously signify other circuit elements.
Void
Quote from: Hoppy on October 01, 2014, 12:56:14 PM
That's a simplified drawing to show an overview of component connections.
It likely was meant to show all components.  :)
All the best.
