0 Members and 715 Guests are viewing this topic.
itsu
Quote from: Void on October 01, 2014, 11:56:16 AM
Hi Itsu. I am not sure if you mentioned it already or not, but did you measure the
inductance of your multi-layer bifilar coil? if so, what is the measured inductance?
Did you wind the 2x24 and 2x12 turns layers in the opposite direction to the 2x48 layer?
By any chance did you measure the full length of the wire you used to wind this coil, or
did you just wind it and not measure the full length of the wire?
I am going to wind my bifilar soon, so just wondering how you have done yours.
By the way, your coil assembly is a work or art. Very nice assembly job! :)
All the best.
Thanks void,
use plenty of electrical tape to restrict movement.
I just measured it, here the data from my Agilent U7133C LCR meter:
121.8uH @ 100Hz,    ESR=0.26 Ohm
145.8uH @ 1KHz,     ESR=0.27 Ohm
139.1uH @ 10KHz,   ESR=0.87 Ohm
121.8uH @ 100KHz, ESR=4.2 Ohm
First layers (2x 48 turns) is CCW, other layers (2x 24 and 2x 12) are CW.
I did not measure the lenght upfront  :-(
I again measured the resonance frequency as it is right now (with all the other coils around it) and the first strong resonance peak is at 4008KHz.
Regards Itsu
NickZ
   Geo has suggested using one wire to wind the bigger air coil. Winding in one direction back and forth. But, That method is not a bifilar wound coil. OR is it?
    I've followed the way that TK's blue coil is wound, including being opposite wound for the cancelling effect.  Hopefully this will reduce the draw from the device's own feed back source.
  There are various ways to go on this. Which way works best, is to be seen.
Or, any way,  that finally WORKS...
Jeg
Quote from: itsu on October 01, 2014, 01:41:39 PM
Regards Itsu
Give me the exact diameter of your pipe and the outer diameter of your wire including insulation
Hoppy
Quote from: NickZ on October 01, 2014, 01:45:06 PM
No, not IMO as the two conductors forming the bifilar should be wound in the same layer. The two wires can then be connected in different configurations. The TK coil shown is a continuous wind of a single conductor intended to form a Tesla type capacitor IMO. However, I'm not sure how its layers are phased. Perhaps Geo can give us exact winding details?
Void
Thanks void,
Regards Itsu
Hi Itsu. Thanks very much for the info.
All the best...
