0 Members and 86 Guests are viewing this topic.
Hoppy
Quote from: a.king21 on October 01, 2014, 04:46:27 PM
Hoppy, and all:  Kapanadze told me that the earth wire can be replaced by a circuit.
When I pressed him further he said it could be replaced by the negative terminal of a car battery.
This is pure Tesla tech. I have read that Tesla used the same technique.
Tesla has stated that in some of his devices you could replace an earth ground with the negative
terminal of a lead acid accumulator (car battery).
I pressed both Mike and his interpreter (who were both present during the aquarium 2 demo)
and both confirmed that the earth wire was disconnected for a few minutes.
I talked to both of them independently and some days apart.
My conclusion is that the earth "ground" is required to keep the device in phase.
I have seen experiments on youtube where the disconnect of an earth wire caused experiments to lose power,
although I don't have these video urls now.
Kapanadze uses high frequency mixing in his device. This is proved by the "dancing meters" witnessed by independent testers of some of his devices.
The only other patent I have found which uses the same technique is by Carlos Benitez.
In one of  his patents he says that an "oscillatory circuit" is required to be mixed with DC to produce OU.
An oscillatory circuit is 19th century speak for "tank circuit".
Akula use the same principle.
Hi a.king21,
Thanks for chipping in on this earthing issue. I'm now of the firm opinion, having studied Akula's various videos, that a ground connection is not essential to operation in respect of being the 'feed' for the primary source of energy to the device. I'm also reasonably sure that TK does not use any sophisticated electronics in the form of nano or PWM circuitry.
Jeg
Quote from: Jeg on September 20, 2014, 12:23:59 PM
The following equation is for accuracy maniacs like void and me! It is tested of course.
By giving the meters of the cable that you decide to use and the outer diameter of the wire including  insulation, you can calculate the exact diameter of the PVC pipe that you need for a 48-48 24-24 12-12 output coil.
R=(L-(1733.28 X D))/1055.04
R, the radius of the PVC pipe or any other material in mm
L, the length of the wire in mm
D, the outer diameter of the cable including insulation in mm
Example.
Length of the wire L=33.75m / 33750mm
Outer diameter of the cable D=3.4mm
Rpvc= 26.4mm So diameter is 2X26.4mm= 52.8mm or 5.28cm
In my case I used 35cm connection cables for each coil ends so in equation for a wavelength of 33.75m I put as L=33.05 m
Itsu, your wire length is 32,095 meters
Keep in mind that when you put in place the 2X25Turns coil, inductance of output coil is changing and high frequency resonance fall down to a lower harmonic. Just measure bifi's resonance frequency when in place so to find the frequency of tesla.
Hoppy
Quote from: magpwr on October 01, 2014, 06:49:20 PM
The snubber circuit which was captured from Ruslan video seems to be very simple only consisting just 1 hv ceramics  capacitor around (2.2nf max possible value 10nf) around 1000volts rating.
The single resistor is just meant for the igbt /mosfet gates to source.
A 10nF cap (600 - 1000V rating) with 100K across it should be fine for the snubber.
itsu
Thanks guys for your comments.
@ magpwr, i did not know there was a 24V version too,  ok i will start with the 2x6 primary (12V version).
@ Nick, not sure what you mean by:
QuoteRemember that Ruslan and Akula are both joining the 12,12 turn resonator coil
(it's not really 25 turns times 2) to the bigger output coil.
Are you saying that the L3 coil (on top of the exposed 2x48 turns part of the big main coil) is NOT 2x25 turns?
Mind you that it DOES resonates at 27KHz with a 0.47uF capacitor attached, i don't think that 2x12 will do that.
@ Jeg, thanks for the main coil wire length (32 meters), not sure why its important as any wavelength/resonance
calculations are skewed in a coil compared to the full length wire.
@ Hoppy,  good to know the snubber details, thanks.
Regards Itsu
zcsaba77
Quote from: MenofFather on September 27, 2014, 11:53:20 AM
In my schematic layer not cansels each other. You not properly read schematic. You can read about dots in woundings and that they mean and if you understand how they say in that side need wound, then you understand, that in my schematic dots is properly puted.
Hi MenoF
Can you explain how mean the dots in coil windings?
Regards zcsaba77
