0 Members and 82 Guests are viewing this topic.
Hoppy
There is an interesting shot in the following video from Ruslan where he shows a nano pulser circuit in a box on the floor which looks as if its been chopped out of a previous build: -
https://www.youtube.com/watch?v=iyDaVspeeNE
Jeg
Quote from: itsu on October 02, 2014, 03:38:16 AM
@ Jeg, thanks for the main coil wire length (32 meters), not sure why its important as any wavelength/resonance
calculations are skewed in a coil compared to the full length wire.
It is not so important when you already know the 5cm ruslan's diameter and his low freq. But if you start from nothing you need some references to unfold your design calculations.
d3x0r
re: http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg417615/#msg417615
the TK (not to be confused with T(insel)K) coil,  has a variety of resonant frequencies...
the resonant primary ( 17-27-37 Khz something ) should be relative to one of these?
Should the kacher be relative to a different one?
I also have a good resonant point at 500Khz give or take a bit.. I added a few turns to the primary so the measured inductances are 260uH and 260uH hoping to get a good coupling with a capacitor on the primary.
The most voltage I get out is at this 500Khz, that takes 5vpp to 48vpp...
I guess this is from the ferrite coil that's added now...
@itsu can also test resonances with just a signal generator at the ferrite input
I think you'll need a tunable delay between when the 494 goes on and the impulse happens...
itsu
Quote from: d3x0r on October 02, 2014, 06:43:36 AM
Hmmm, i do not know what you mean as i have no ferrite in use yet (just winding the yoke now, do you mean that?)
"a tunable delay" yes i guess so, that would be a challenge for me to build.
Regards Itsu
d3x0r
Quote from: itsu on October 02, 2014, 07:17:06 AM
Regards Itsu
no actually I was originally thinking of testing just the coil... but I recently added a ferrite core (yes the yoke) but can test the other resonances without the core...
was just thinking though that I didn't previously have this other 500k frequency
the tunable delay was the 7400 things dally used.... it's also kinda what the 7414/7400 module does...
