0 Members and 467 Guests are viewing this topic.
Void
Quote from: magpwr on October 03, 2014, 07:12:25 PM
hi void,
Last night i have seen the part in Russian forum where "he" will select certain capable Russian members for some online group chat.
It's best not to intervene as Russian members in forum also do have difficulty in understanding his ou device.
"Let nature take it's course" :D
It was just a comment on what Ruslan is apparently up to.
By no stretch of the imagination can this be construed as an intervention.  ;)
All the best...
d3x0r
Quote from: magpwr on October 03, 2014, 07:19:11 PM
hi Jeg,
I have seen circuits which are powered by signal using only 2 wire -1 signal 1 negative.
I don't recommend diode to be there because i like the input signal around 27khz to stay clean /less distortion at the input stage and it's better to use 7805 or 78L05 voltage regulator instead as already implemented in nano generator circuit.
still have to have a cap before the regulator then so you can keep as much of the low power signal that you can to delay the time... yes the diode reduces the voltage a bit, and it may cause thresholding issues... but really I'd think the pulse would be slighly after the 494 turns off... and this target configuration is really a short impulse signal requirement anyway, so that cap can go even smaller.  the other was triggering a resulting pulse train instead of an impulse.
akula is keeping constant power on them... could add the 7805 ... but otherwise you definatly need the diode... otherwise any power stored will be drained when the 494 goes low ... or any where along there like on the mosfet driver,w hich is really good at making things go low, so the capacitance will just drain wasted .... need a diode. 7805 can also help.
magpwr
Quote from: itsu on October 03, 2014, 03:55:36 PM
Magpwr,
thanks again for all this info.
From your Akula drawing i added the R2 and diode coming from the other MOSFET driver and sure enough, it
now closely match the red, blue and green signals from both this Akula and Ruslan diagram......., see screenshot 1.
Could it be that whomever draw this Ruslan diagram "forgot" this R2 and diode connection?
Just to be clear, i mean the R2 + diode as can be seen in the purple square below.
Regards Itsu
hi itsu,
This addition of R2 + diode  might be the improvement  over the old design.
The duty for yellow signal seems to be more than 50%,unless it there to clearly show us the another 2 signal below.
everyone,
If you take a look at Page 116 of the Russian forum.
In "hacksoft" posting- used a PIC10F200 circuit to generate waveform to the right.
Do observe the blue and the red waveform and nanopulse seems to appear between the blue and the red waveform
The final waveform is below in that picture.
I have seen this final waveform somewhere from Akula video maybe.I can't recall which video or which part of video or picture.
I am curious if the final waveform in sine-wave should logically look like this shown in forum once nano pulser is superimposed onto 27khz or tesla coil frequency.
Photo from page 116-
http://realstrannik.ru/media/kunena/attachments/5732/SchSmallBTGVer1.gif
Hopefully some can help find the waveform in Akula video where scope is used or picture so that i can be sure this is the final waveform after superimpose.
Void
Quote from: magpwr on October 03, 2014, 08:13:52 PM
No, the diode and capacitor you are referring to was part of Akula's schematic for his
second self runner. The schematic you have been referring to is just a patched together
kludge incorporating different things that someone threw together which was not tested.
magpwr
hi everyone,
This is my first official Tesla coil which i have created by hand using 20AWG on around 5cm diameter PVC pipe,coil height around 12inch/30cm.
It's hard to close all the air gap using 20awg.The choice of magnet wire thickness was selected after noticing the thickness of tesla coil at the end in Ruslan device.
Winding is completed in around 1.5hours without cutting pvc pipe to let it rest on my lap during winding.
Resonance test not done yet.
Next stage i would need to wind the multilayer coil on existing pvc pipe without "cutting it up fully somewhere in the middle ".
Latest update-Using L/C meter to measure tesla coil twice i got 1.069mH at this moment without the large outer coil in place.
Related to my other project look what i have got.
2 High voltage Brand "Custom" capacitor-
