0 Members and 243 Guests are viewing this topic.
magpwr
Quote from: d3x0r on October 04, 2014, 10:02:38 AM
can you dig up a reference for that?
hi d3x0r,
I do advise to check on my previous posting on where i obtained the information and not forgetting the pdf from Akula speech which i have attached previously.
The pdf which allowed me to decode to kick start this forum to provide a much deeper level of understanding than the past.
Jeg
Quote from: magpwr on October 04, 2014, 09:21:07 AM
.... but take note the 2 outer larger coil is cw & ccw this time base on my observation.Double verification on this part is needed.
Mag about what coil you r talking ?
magpwr
Quote from: Jeg on October 04, 2014, 10:13:09 AM
Mag about what coil you r talking about?
hi Jeg,
I need assistance to double verify if the 2 large outer coil(One on tesla coil and another over multi layer) are cw,cw or cw and another ccw once the "2 turns winding" is used to link tesla coil to antenna over the multilayger coil.
This "latest" device is reveal in Ruslan video where there was removing the electrical box using a drill to show what is inside while the device is in operation.
The 2 turns was first spotted by itsu.The older version was the ferrite where there is CW and CCW winding done on ferrite, but i think the older version both the 2 outer large coil is aligned eg:cw&cw or ccw&ccw.
Please assist as my eyes may deceive me hence double checking is preferred for this area.
It would be easy to change winding direction of large outer coil at the multi layer coil once confirmed.
Jeg
My opinion on this according to my understanding and experiments is that
1. You put the outer primary coil of Tesla in the direction which needs for the Katcer to work. No problem if it is CW or CCW. Katcer works with only one direction primary and this depends on which direction you wound the Tesla coil itself.
2. Radiator's direction do play a role as it is one direction pushing and it has to be in a way as to force the low frequency down to zero or lower during the whole pulse train of spikes. While doing this, the coil reacts in an opposite manner and gives a positive narrow current pulse for each time you force it to go down to zero level or lower. At the end of each cycle, the mean value of current will be higher than without katcer's pulses.
3. Ferite between Tesla and radiator is just for frequency correction. It is not there for making the pulse narrower because we anyway bring in resonance the granade coil at lets say 1.8MHz and even if you give it a narrower pulse, this coil will react in a time according to its resonant frequency. Which is 1/1.8MHz.
According to this last paragraph, the two turns in the air in place of the ferrite in Ruslan's latest photo, is there only by accident or for a Hertz order frequency correction which is unnecessary.
Ps. T1000 mentions about loading positive only cycles. This is because if you do the same to negative, you give back to the environment what you gain during the positive cycle. At the design of the future we will load negative cycles also, but at the opposite side than we do to the positive cycle. This eventually will double the output power.
magpwr
Quote from: Jeg on October 04, 2014, 10:52:05 AM
My opinion on this according to my understanding is that
hi Jeg,
Thanks Jeg for your input.
But i would "like" to ask you again what was your visual findings on the large outer coil if it is aligned or it is cw & ccw base on the latest device with 2 turns.
For me the smallest details does matter-
For example if the old device outer coil winding direction is aligned on tesla coil and antenna coil over multilayer.Then a ccw,cw winding was applied on the ferrite.
Now looking at the latest device it looks simple 2 turns coil instead of ferrite rod with cw,ccw.
But observe carefully the direction of the 2 outer large coil seems not aligned this time it seems like cw and ccw formation which makes a world of a difference if you are constructing the device.
Using the ferrite rod is a  little complicated one reason being we don't know what is the actual core material used/PERMEABILITY is unknown.Someone did ever mentioned material 61 or 66 for ferrite which i can't fully recall or to verify.
Related to ferrite-The only hint i know Ruslan mentioned it is MF or Medium frequency which covers up to 1.7Mhz or 1.8Mhz which is easy to verify base on Tesla coil resonance frequency.
