Jeg
Do you remember in which page is the photo with this coil that you r talking about?
My winding directions are copied from this link which published by GF
http://realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=1620
Page 91
NickZ
  I don't think that the pvc pipe former for the air coils, is 5cm. It looks more like 1 1/4 inch tube, or less for the blue TK coil. Could also be a 1 1/2 inch pipe.
So, 1 1/4 to 1 1/2 inch former. But, not 2 inches, or bigger.
  I also don't think that the resonator coil is 25,25 turns, as only 12,12 turns is seen on both Akula and Ruslans, or TK devices.
  The Kacher secondary is not much over 6 inches long, possibly 20 to 22 gauge.
  And I feel that there is a purpose for the ferrite rod frequency tuner coils, and not just using a couple of turns in the air, like Ruslan is showing.
The device probably works without this ferrite rod, but not as well. Otherwise Akula would not have used it.
  Hoppy: I got my new Mazill crt working now. The problem was a combination of one bad solder joint, and possibly a bad new battery. The device works ok with my 12v, 10 amp battery charger. But, the brand new battery will not hold the charge, and I may have to replace it with another one. Voltage drops too much when the device is turned on. Which also makes the fets heat up, as well, as you have previously mentioned.
My fets, IRFP260N (6 pack) are all a bit different from one another, and so are  their output readings.
I'll screw the fets down in place on the heatsinks when I find the right size drill and screws, as the motherboard heatsinks don't have the mounting hole in them.
  Guys: You can wind the aircoils with the same winds on each layer by placing a pin, or a thin two inch screw, through the former pipe, on the ends of where to first wind is. That way the other winds will aline the same, or nearly so. The other smaller coil turns can be held in place by tape or tie wraps.
But, I don't think that that it's all that important.
Jeg
Nick, Ruslan himself spoke about 37meters or close for making the grenade, which correspond to a 5+ cm diameter meter. He also said 11meters wire for the inductor which correspond to 25+25 turns. Perhaps later he changed the design. Can u pls attach the picks where you see 12+12?
magpwr
Quote from: Jeg on October 04, 2014, 11:46:05 AM
http://realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=1656
hi Jeg,
It's ok.I have just cracked\solved this outer coil winding direction mystery  in 3 minutes using another alternative verification approach.
The answer is shown below-
everyone,
Base on latest video of Ruslan where he removed box cover for his latest device while in operation-
Пояснение по работе Генератора СЕ
http://www.youtube.com/watch?v=xOc-7EXMvNc
Base on my observation and justification why only 2 turns is used instead of "ferrite rod with cw&ccw winding" is because i have spotted both large outer coil(On tesla coil and another over multilayer coil) winding is not aligned this time it is eg:cw and ccw for the latest current device shown in video.
If you observe the ending for the both outer coil is facing in the opposite direction this means the winding direction for the large outer coil is different this time-
I have attached screen shot from video for the justification purpose-
It's past midnight now.Time for me to relax. :D
Jeg
Very nice Mag. If we could find the relative direction of granade also, it would have more sense. If you look at the picture at my previous post attachment, there all the directions can be shown.
Nick if you spoke about this pic that Mag attached, yes it looks like it has 12+12 and heavier gauge wire than the grenade.
