0 Members and 25 Guests are viewing this topic.
magpwr
Quote from: Jeg on October 04, 2014, 12:21:18 PM
Very nice Mag. If we could find the relative direction of granade also, it would have more sense. If you look at the picture at my previous post attachment, there all the directions can be shown.
Nick if you spoke about this pic that Mag attached, yes it looks like it has 12+12 and heavier gauge wire than the grenade.
hi jeg,
Please follow itsu.We have already sorted out the receiver portion few days ago and i have pasted my coil spec with the number of turns awhile ago for Hoppy.
That's all for now.I need to charge my batteries. :D :D :D :D
Hoppy
Quote from: NickZ on October 04, 2014, 11:58:09 AM
  Hoppy: I got my new Mazill crt working now. The problem was a combination of one bad solder joint, and possibly a bad new battery. The device works ok with my 12v, 10 amp battery charger. But, the brand new battery will not hold the charge, and I may have to replace it with another one. Voltage drops too much when the device is turned on. Which also makes the fets heat up, as well, as you have previously mentioned.
My fets, IRFP260N (6 pack) are all a bit different from one another, and so are  their output readings.
I'll screw the fets down in place on the heatsinks when I find the right size drill and screws, as the motherboard heatsinks don't have the mounting hole in them.
Nick,
Good news! Go for a much bigger battery, say 20A/hr or bigger. When you drill holes in the heat sink, make sure you lightly countersink the holes, especially on the surface so that the mosfets lay completely flat on the heat sinks.
Hoppy
I agree, it would be most helpful to have a clear pictorial winding instruction showing directions of wind from a fixed reference point at the start of winding at thin end of the grenade.
d3x0r
Quote from: magpwr on October 04, 2014, 12:13:53 PM
It's ok.I have just cracked\solved this outer coil winding direction mystery  in 3 minutes using another alternative verification approach.
I like the notes on the kapagen coil... (I lost my images so I'll have to dig for it...)
an originalish is heree... you can see the winding directions pretty well... http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg408309/#msg408309
Hoppy
So we have 48-48 cw, 24-24 ccw, 12-12 ccw as viewed from start of winding at thin end of grenade - yes?
