0 Members and 23 Guests are viewing this topic.
itsu
Quote from: Hoppy on October 04, 2014, 04:07:49 PM
So we have 48-48 cw, 24-24 ccw, 12-12 ccw as viewed from start of winding at thin end of grenade - yes?
Nope,  not me, i have 48-48 ccw, 24-24 cw, 12-12 cw  as viewed from start of winding at thin end of grenade
like in this picture:    http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg418454/#msg418454
Regards itsu
magpwr
hi everyone,
It's Sunday morning 6am here.I took a quick peek in Russian forum at Page 116 latest update-
Ruslan have posted his comment which i just translate to english-
To begin, the entire assembly Prepare the wire of 2.5 mm square 50m, 60cm tube length and diameter of 50mm, Ferro-core from the telly or monitor the operating frequency of 25-75 kHz oscillator push-pull collect as you want, you only need a good and stable operation of the rectangle .  It is advisable to all PCB and locking konedensatorami for interference.  As Generator BB will use 2SC5200 transistor in place KT805B (although it can be), the rest is done by the scheme Roma Shark that he vykladovat.  It's about the explosive generator.  On the way out, we should get a clear pulse of 5-7 kV.  More is better of course (http://www.realstrannik.ru/media/kunena/emoticons/blink.png)  Frequency air-core transformer coil podstraivaetsya counter is enabled from the explosive cores on anttenu (http://www.realstrannik.ru/media/kunena/emoticons/wassat.png)  We must not get our magical transformation coil and Absorption of radiant energy in the environment by using pulses of explosives.  This nasamom business is not difficult, but requires some subtleties.  One of them - Earth + getting cold energy and discharge it into the condenser.  Very similar to what I did Bidin.
Why the doubts guys on certain simple things eg:winding which is easy but i know human mind tend to think more complicated than the device itself.
"It's just the way this have been for humans,can't blame anyone"
This information i have pasted is now "straight from the horse's mouth" the device creator himself-
The only part i honestly  can't help is  the high voltage probe at least 10kv rated is needed to observe nanosecond burst for the scope ,if you treasure your scope. :)
Time to continue my sleep cycle. :D
AlienGrey
Hi that's a big chunk of guttering down pipe, are you using a solid 2.5mil inner conductor or a multiple strand cable? and does it make a difference in what direction you wind any of it ?
One thing to mention if you look at all the other systems like the Akula unit he is only 32mm Kacha coil sliding in and out of a 40mm grenade type coil and it looks the same with the Ruslan device also, just an obviation.
magpwr
Quote from: AlienGrey on October 04, 2014, 07:02:10 PM
hi AlienGrey,
It's multi-strand 2.5mm sq on 5cm dia pvc pipe.
I have also attached the coil spec i would be using for the last time.
I shall not repeat winding procedure anymore.All the other details please refer to older posting of mine less than 2 weeks ago.
Lastly i have attached Kapanadze coil turns image for winding guide.Do observe the long wiring from top of 48 turns to bottom of 24turns is done which you need to apply for Ruslan winding.
"The only missing from the old Kapanadze coil is the 25,25  turns layer which a "larger outer coil" which is present in latest Ruslan device
I am more focus on Ruslan but circuit Akula's.There is alot of mixing going on but i am not worried. :)
If you are unable to recall easily please take down all the important pointers.It would be better approach for everyone as well.
Void
"One of them - Earth + getting cold energy and discharge it into the condenser.  Very similar to what I did Bidin. "
Inferring from the iffy translation, it appears Ruslan may believe that you need to discharge the
output through a diode to a capacitor to capture the output energy, but Akula did not
show a diode going to a cap at the output in his second self runner schematic. Akula just showed
going through a choke to a 5nF capacitor. Ruslan previously mentioned using 37.5 meters wire length
for his multilayer coil (I think that is the coil he was referring to) on a 40mm diam tube, now he seems to be saying
to use 50 meters of wire on a 50mm diam tube.  ;D  No shortage of conflicting info from these guys,
but the general approach in their devices appears quite similar. Ruslan is still saying he will
reveal all the info on his approach soon, from what I understand using Google Translate anyway.
