d3x0r
Quote from: magpwr on October 05, 2014, 11:39:56 AM
hi everyone,
Base on this attachment nanopulser-27khz.
The only way i know in order to get similar waveform is to switch on tesla coil to fire at the peak of waveform eg:27khz which is already in sync with pwm generator via nanosecond generator.
Then you're ignoring what I'm posting because I asked for a link to the message with the pdf?
magpwr
Quote from: d3x0r on October 05, 2014, 12:49:47 PM
hi d3x0r,
I did advise you to check my less than 2 weeks old posting to obtain the pdf from attachment.
I have attached the pdf. ???
Hoppy
Hi Mag,
Good work.  :) Are you still running with the 1K2 pull-up resistor to the pos rail, thus eliminating the other two mosfets?
NickZ
  I've been using my 12v, 10 Amp battery charger lately, to power my Mazilli/yoke crt, but it doesn't light the 3 100w bulbs I have connected now as brightly as a 12v battery will.
  My brand new 12v, 7aH battery, is not discharging into the circuit properly, voltage drops to 6v, immediately at turn on.  I don't know what the battery amperage that is being drawn from the battery is yet, and it seams that the battery may be defective. I'll know more soon.
  In any case the battery charger's input to the circuit is 12v and something like 10  amps.  It may be a somewhat lower amperage draw than that,  but not higher.
  Hoppy: I wonder if my battery charger could be connected to the device's air coils 110v output, (instead of to the grids ac source), and this 12v output once reduced to 12v DC can be sent back to device's input side, as 12v???
It's not a switching power supply, but, the older car battery chargers with the heavy iron core transformer.  Could that be used in place of the 120/240v to 12v power supply shown?   Yes,  No?  Possibly...
d3x0r
This sim has the same spikes
it's just that the drives shows up as a significant force, that there's a 'large' resistance to the resonant tank
given enough time this spike will diminish more
should have put a resistor in it too... but it already had the impulse
