0 Members and 357 Guests are viewing this topic.
Jeg
Thanks Nick. Ii is an insufficient system anyway by itself. If katcher will improve it will be a good start to develop something better.
Itsu, i had uploaded the same waveform with this ringing a while back. Normally the diode which is connected in series with the 2,2nF cap has to face down to the ground for the cap to charge fast while oscillating with the half yoke primary. This ringing has the frequency determined by the half primary coil combined with the 2,2nF and the capacity of the diodes. That's the why it doesn't ring with just resistor in place of coil. It is irritating but if you make resonance at secondary side, it is being eliminated enough.
Mag, your second approach is more close to me, but i am also thinking better ways for doing it as it has some drawbacks.
Something very interesting about the multilayer grenade coil that perhaps you didn't notice yet. The magnetic field that takes place in that coil form, is in such a way as to create two similar poles at each ends. About at the middle of the coil, the other two poles are squeezing each other. Use this info to predict the relative winding directions of Tesla coil and its radiator.
d3x0r
Quote from: itsu on October 06, 2014, 08:18:31 AM
d3x0r,
i never measure the resonance of a coil with the (50 Ohm impedance) signal generator directly attached to this coil, i always use
a separate 2 turn wire coil around the coil to be measured.
When i do that (multilayer coil grounded at one end, the scope probe across this coil), a measure the following resonances
(sine wave signal when inputting 5V square wave):
944KHz 20Vpp
2.115KHz 10Vpp
3.965KHz 12Vpp
Concerning the inductance of this coil, i did mention that here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg418931/#msg418931
but as i now have attached the yoke to the L3 coil, there are some slight changes as now i measure:
100Hz    146uH
1 KHz     146uH
10 KHz   145uH
100 KHz 87uH
Regards Itsu
so 1.888Mhz (suggested target kacher, irrelavent for impulse)  is 2 x 944... and the other should be 29Khz or 59Khz probably...
something like 206nF...
hmm what about your 25+25 turn coil's inductance?  also 146uH?
magpwr
Quote from: Jeg on October 06, 2014, 09:22:09 AM
hi Jeg,
Since you have mentioned about 2 poles.There was this Russian video which a compass was place near a coil which get compass to move.
Anyway there is nothing in that video worth mentioning as i recall.
itsu
Quote from: d3x0r on October 06, 2014, 09:22:29 AM
Well, its now connected to the 3 turn coil on the yoke, so hard to measure, but as it was resonating at 26.5KHz with 465nF, it
calculates to be around 78uH.
Regards Itsu
magpwr
Quote from: itsu on October 06, 2014, 09:50:23 AM
Regards Itsu
hi itsu,
I understand previously that you have completed building the device once we got the receiver coil specs.
I do fear that you have not factored in the oscillation frequency of Tesla coil once the antenna is in place over the receiver/multilayer coil.To get to 1.7Mhz ...1.8Mhz. recall 27.xxxkhz for the yoke is also the sub-harmonics for the 4.8Mhz or 1.7Mhz..1.8Mhz(3rd harmonics) base on the excel spreadsheet which i have also previously attached twice.
If you observe carefully at the Tesla coil portion for any of Ruslan device.It length of tesla coil itself is barely 12inches/30cm.
My 1st hand made Tesla coil is 30cm ,inductance reading at 1.069mH on 5.5cm dia pvc pipe using 20AWG(Base on observation)  and it is resonating at 1.3Mhz which i will be reducing the winding at the later stage.
Once i have completed the nanopulser portion to pulse in 1 or 2 KV for a start.
The circuit itself is completed but i need to figured on how to interface with the device which there is 2 possibilities left which i have mentioned in post couple of hours ago.
The part which i don't understand why is Ruslan using 2 x 0.47uf 2000volts, 4 x 0.47uf 2000v in parallel configuration as spotted in 1 or 2 videos.
The combine uf value seems to be matching with microwave caps 2000volts around 1uf...1.8uf which is seen in older Akula video.
