0 Members and 526 Guests are viewing this topic.
magpwr
Quote from: Hoppy on October 08, 2014, 03:22:01 AM
Mag,
Thanks for comments on the purpose of the NTC5.
That's an advantage I have living in the UK. Next day delivery on almost any component.  :) Having said this, it does not include TV yokes that are now pricey, even on e-bay. Best bet is visit your nearest refuse centre and look for a big old TV. My refuse centre does not allow the public to take electronic items but a few bob dropped.... :) Better still try to get hold of one of those magic Russian yokes.  ;D
You commented back Jeg in post 5438:-
"hi Jeg. Honestly i am not interested in Brutto drawings like he is the teacher for Ruslan. Don't you find it's silly constructing a step up secondary coil on yoke and connecting a bulb to it. These are the silly things which prevent people from progressing in this topic for so long"
Please explain why you think this is silly.
hi Hoppy,
Base on the way the yoke is setup (6-0-6 for 12volts /12-0-12 for 24volts) around 2.5 mm sq and at the secondary  which is consist of 3 turns(Which looks like 4mm sq) and 28 turns around 1.5 mm sq or 2 mm sq.
The output of 28turn
s is actually going to the bulb 3watt*...10watt which serve as an rough indicator if the yoke output voltage is at the optimal.The bulb is optional it's up to individual to leave it there or take it out once tuning is done.Then it is rectified to a full bridge rectifier which is made up of 4 x ultra fast diodes around 400...600volts.From Full-bridge it needs to be connected to the high voltage capacitor which i have mentioned around 350volts..450volts.This capacitor is the energy storage for the nanosecond pulser which will generate pulse in kv.
(Brutto drawing is incomplete version which is full of blocks diagram)
I have merely finished talking about 28turns which can winded higher to yield higher dc voltage maybe up from around 150volts to around 190volts to ultimately achieve maybe say 1.2kv...3kv to around 6kv or 7kv.
Now 3 turns winding looks strange which is also connected to the 0.47uf 2000volts capacitor x 2 or x 4 in series to the 25 turns in the multilayer coil which a large outer coil hover over. :D
Only through actual testing of yoke core can reveal if these 3 turns coil is actually providing the eg:27khz(Following the pwm generator for yoke).Test needs to be conducted to verify this.This is likely but not confirmed.
Put it simply the yoke core is serving 2 purpose to eventually provide high dc voltage and another eg:27khz.
But why the high voltage rating capacitor 2000volts.
This is not confirmed just theory so please do argue with me-
There was a word elastic mentioned somewhere in the pdf which is created base from  the speech of Akula Tesla coil tuning video.
I repeat don't argue with me as this part on is already long shot theory in my head-
The 27khz was send into earth has this elastic effect like a thin rubber band which pull then shot into earth and then return back to the yoke core with higher amplitude of 27khz via the 25,25 turns which the outer coil hover above it.Note this freq is just an example.
Selecting the 0.47uf capacitors x 2 or x 4 is base on one of the harmonics resonance of 27khz or 1.7Mhz.I don't know how this part is done honestly.
"A car looks very simple from the outside like the kapanadze device photo, but once you started to dig deeper to know what each an every component functionality is.
You will fnd that it is complicated for the novice like us"
itsu
Quote from: magpwr on October 07, 2014, 06:24:10 PM
hi itsu,
May i ask can your "High voltage probe" detect nanosecond pulse base on old circuit which you have created some time ago.Eg:1.5volt version or etc.
The reason being my 40KV   x1000 probe is unable to see anything .No waveform detected for nanosecond.
If your HV probe is able to detect nanosecond can you provide me your probe model or spec.Thanks.
I have made a wrong move few months ago. :'(
Magpwr,
my 200MHz Owon scope with the Pintek HVP-15HF HV probe (scope set at x1000) is able to "see" my ~10V / 800ps pico-pulse allthough
somewhat distorted, see screenshot 1
The HV probe used is as said the Pintek HVP-15HF probe, see screenshot 2, found on Ebay.com.
Regards Itsu
itsu
Quote from: magpwr on October 08, 2014, 05:10:11 AM
Magpwr,
i did show here: http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg419394/#msg419394""  that it is
true that the 3 turn coil linking to the 2x 25 turns L3 via a 470nF cap. is causing a 27KHz resonance (sine wave) signal following
the TL494 frequency set to 27KHz.
Regards Itsu
magpwr
Quote from: itsu on October 08, 2014, 05:30:05 AM
Magpwr,
Regards Itsu
hi itsu,
Thanks.I will execute purchase without second thoughts this time.
The 40KV probe i previously purchased was around this price.It was suppose to be a one time purchase purchase for "probe". :'(
Final findings for today-
Base on Ruslan video -http://www.youtube.com/watch?v=2akNL5k2xNA
and https://www.youtube.com/watch?v=nB4Bm1ygYMg
I have attached image to explain this time.
itsu
Quote from: magpwr on October 08, 2014, 06:17:03 AM
Magpwr,
Some remarks concerning those video's:
# you can hardly call that left (~17 turns) flat wire secondary a Tesla coil, no sign of any (underlaying) Tesla coil either, also no
connection to the right "grenade"coil combo.
# Neither this 17 turn "tesla coil" nor its primary is connected.
# The scope shows a 15.3Khz clean sine wave of 8Vpp coming from this red paralleled capacitor (2x 470nF = 940nF?).
Where does it come from / goes too?
# The other red capacitor (laying flat) and also presumable 470nF is connected in series with one of the white leads coming from
the 3 turn coil from the yoke and going to the Grenade coil (2x 25 turn L3?).
So adding more confusion then clearing up   :( , only the last item seem to fit with what we (i) got.
Regards itsu
