0 Members and 246 Guests are viewing this topic.
magpwr
Quote from: itsu on October 08, 2014, 07:20:38 AM
Magpwr,
Some remarks concerning those video's:
# you can hardly call that left (~17 turns) flat wire secondary a Tesla coil, no sign of any (underlaying) Tesla coil either, also no
connection to the right "grenade"coil combo.
# Neither this 17 turn "tesla coil" nor its primary is connected.
# The scope shows a 15.3Khz clean sine wave of 8Vpp coming from this red paralleled capacitor (2x 470nF = 940nF?).
Where does it come from / goes too?
# The other red capacitor (laying flat) and also presumable 470nF is connected in series with one of the white leads coming from
the 3 turn coil from the yoke and going to the Grenade coil (2x 25 turn L3?).
So adding more confusion then clearing up   :( , only the last item seem to fit with what we (i) got.
Regards itsu
hi itsu,
You got me wrong.The Flat is not a tesla coil it is a possible way to inject high voltage nanosecond pulse via tesla coil."I wonder if there is nanosecond surge in kv and combine with existing high/frequency at tesla antenna what would be the scenario like"
The Flat coil seems wound over tesla coil.
You will see to see another video to notice the tesla coil length and thickness which i mentioned previously it is around 20AWG.
I have attached this screen shot "Alternative view " previously to justify on the outer coil windind direction base on that video in one of the frame of the video you should able to see the magnet wire thickness on the yellow tape portion.There should be no confusion.
All video are base on Ruslan.
What i was highlighting do observe to justify the length of the tesla coil itself to be Oscillating at around 1.7Mhz...1.8Mhz.
The 2 video i have link is the unassembled version and a partially completed but partially incomplete unit to power those high watt bulbs.It's the same device.
If you notice the sequence of video upload for this device in date do not match.This is not important but can be confusing for many whom always latest uploaded is the latest stuff.
Ans:He was various colour wiring from electrical connector.
from 3 turns it is going to capacitor then it became brown wire from connector leading to device.The signal below <18khz and brown wire from white wire from yoke is just a decoy or extended wire.
Important thing to note the waveform obtained from probe which was connected to both leads of 0.47uf x 2 parallel capacitor is a sinewave.
We now clearly know "The 3 turns" it's following the pwm generator signal.
Another thing to note the sinewave vpp is 16volts at 15khz at the 3 turns of the yoke core this is based on 24volts supply which is driving the yoke core.
Please don't be concern ovre 15khz recall Akula mentioned for air core <18khz it don't make sense something like that found in the only pdf which i previously created from the tesla coil tuning video.
No confusion please.
Base on the long story i wrote above this is the short version-
1)3 turns of yoke follow pwm generator frequency
2)Signal between 470nf is a sinewave
3)I just mention about the nanopulse possible point at tesla coil with the flat wire
4)I wanted to show you that the winding of your tesla coil is wrong hence i need to justify the length of tesla coil to get 1.7mhz...1.8mhz with all the antenna connecting wire/outer coil over multilayer.
That's all for today.I need reminder energy for experiment.
itsu
Quote from: magpwr on October 08, 2014, 07:40:42 AM
hi itsu,
But as i said,  "no sign of any (underlaying) Tesla coil either", so there is no "tesla coil" anymore!!
Quote# The scope shows a 15.3Khz clean sine wave of 8Vpp coming from this red paralleled capacitor (2x 470nF = 940nF?).
I don't think so, see path from white wires, also lateron in the video you can see the left white wire goes to the 2x 25 turn coil.
Regards Itsu
magpwr
Quote from: itsu on October 08, 2014, 08:00:06 AM
Regards Itsu
hi itsu,
I have attached my last justification for 20AWG tesla coil for today.Ignore file 2 turns tesla for file name it's for my recall only.
There are people whom are much better than me in "reverse engineering" eg:Ruslan his nanopulser was based on Akula circuit.
itsu
yeah, but this picture is not from those 2 last video's you published and there i was commenting on.
Never mind, lets continue.
Regards Itsu
Jeg
Quote from: itsu on October 08, 2014, 08:25:38 AM
Regards Itsu
Itsu can you please measure how many KHz is your yoke's primary oscillation? The one that you consider as parasitic. In my previous yoke arrangement with 12 12 primary was around 600khz. Now with 6 6 turns primary is around 870khz.
