0 Members and 31 Guests are viewing this topic.
d3x0r
re: itsu's spikey yoke drive..
other than trying to throw things at the problem to 'fix it' what is causing the problem?
I would think if the drains were shared than it wouldn't have triggered the 50ohm resistors right ...
would a bigger choke fix it?  (if you added a choke to the 12V input to the yoke like a mazilli... )
1) fet A turns on, conducts side A, large electron current change results in inductions on all other coils... including side B... which should be electron current in the opposite direction, so from + to the fet side...which is a large negative at the fet.  Doesn't a fet have a body diode that allows that to conduct?  Would think you should block that flow from the drain entirely with a diode... and maybe a capacitance....
or like what's the drain-gate breakdown?... if you lower the drain below the gate .. does it end up triggering to be 'on' ?
And using a square wave, are you sure the pulse should be so very wide?  I approach it from a lowest power standpoint... and if you pulse width was say something like 900kHz, with a overall pulse of 27kHz(something... the low coil's resonance) ...  It could be that there's not enough load to the transform for such a wide pulse of 12V input... that it's like in a clipping/overdrive sort of mode maybe
DRJOHNBULENTATES
I am not cousin of kapanadze
I saw 100 kw test in Turkey 3 phase
I heared that they stopped all works
thats why I made one myself and saw all tricks. But system is working without spark well
no need GROUND
I made new mixed with Hendershot
you wont believe but 40 times more power than Kapanadzes coil
DRJOHNBULENTATES
Quote from: DRJOHNBULENTATES on October 08, 2014, 04:22:56 PM
no need GROUND
starcruiser
no need GROUND
Can you share those tricks? Perhaps a diagram (schema) that shows your take on it? I am speaking of the TK devices. Then if you would start a new thread on the improved version you speak about.
Would like to understand and replicate if this works as advertised.
Regards,
Carl
NickZ
   Hoppy:
   Got any suggestion for modifying my 12v, 10A battery charger to work at one or two amps? To be able charge my 12v, 7ah battery, properly?  Something simple...
