0 Members and 73 Guests are viewing this topic.
Hoppy
Quote from: NickZ on October 08, 2014, 04:39:43 PM
   Hoppy:
   Got any suggestion for modifying my 12v, 10A battery charger to work at one or two amps? To be able charge my 12v, 7ah battery, properly?  Something simple...
Nick,
A decent SLA battery charger normally has two or three stages of charging, so you cannot easily modify your charger to charge SLA's properly.
My suggestion as I made some time back is to get yourself an old car battery or two and use your charger for these. These batteries should if not in too poor condition, be more able to supply the level of current required to drive your Mazilli load. You could also try conditioning them on a simple Bedini solid state energiser.  :)
magpwr
hi itsu,
I saw the ringing in your waveform and i spotted someone at 4HV.ORG had somewhat the similar the similar problems to yours.
Base on similar ringing waveform the solution a another person applied for his tesla coil project was to up the capacitor to 4700uf across the power supply rail near to the yoke.
Please see attachment-
Please don't trust fully trust the snubber portion in Akula circuit.If the above solution i provided don't work at all.
Are you using fast diode for snubber section?
Do try to search for alternative solution related to tesla coil ot flyback driver or snubber circuit design idea.
d3x0r
Quote from: magpwr on October 08, 2014, 06:33:22 PM
hi itsu,
that would almost be like adding a transformer in parallel... primary across + secondary across - of power supply...
Void
Quote from: DRJOHNBULENTATES on October 08, 2014, 04:22:56 PM
I am not cousin of kapanadze
I saw 100 kw test in Turkey 3 phase
I heared that they stopped all works
thats why I made one myself and saw all tricks. But system is working without spark well
no need GROUND
I made new mixed with Hendershot
you wont believe but 40 times more power than Kapanadzes coil
Hello John. Welcome to the overunity.com discussion forum.
Sounds interesting. Would you like to share some details
on Kapadnadze type devices or related?
I believe this is one of your videos of a kapadnadze style device using a spark gap?
http://www.youtube.com/watch?v=pQZkTRgwFWY
All the best...
URFA
QuoteI am not cousin of kapanadze
no need GROUND
Merhaba Bulent.
Öncelikle bu forumda Türk birini görmek nasip oldu  :D Hoşgeldin.
Foruma çok iyi bir giriş yapıp bizleri söylediklerinle heyecanlandırdın. Konuyu biraz açabilir misin. Sen kıvılcım boşluğu ve topraklama olmadan Hendershot tarzı bir cihazmı yaptın? Komple cihazın sırlarını açıkla demiyorum ama en azından elinde video varsa paylaşırsan seviniriz.
Teşekkürler.
Ibrahim
