0 Members and 254 Guests are viewing this topic.
magpwr
Quote from: Hoppy on October 10, 2014, 03:21:41 PM
Mag,
Thanks for your post on the PWM to Nano synch connections . Good idea about a switch for the channels.
Please expand on the above pulse capacitor. Are you referring to C37, the 500uF cap supplying the primary coil of the Karcher shown on your edited Mikmur circuit?
hi Hoppy,
I believe you might have seen this Pulse capacitor capacitor used in Ruslan video and in Vasmus device.
It's a Russian PIO capacitor (Brown) around 400volts.
This PIO capacitor 6uf<10uf (Base on rough max value found base on it's dimension used in actual device .This capacitor needs to be connected in parallel with existing high voltage electrolytic capacitor around 350volts with around 180uf.It was spotted in one of the Ruslan video i can't recall which of the less than 5 videos.
Reason why this PIO capacitor is used is because it's got "high rate of discharge" than compared to electrolytic capacitor.Hence it is suited for nanosecond pulse application to get kv.
(Do search in the internet which capacitor type is more suited with high discharge rate and got higher than 4uf for value.There are better ones.Why the brown capacitor selected is because of easy availability in Russia for this application)
This PIO capacitor and electrolytic capacitor will need to be connected after the full-bridge rectifier (Using high voltage fast diode around 400volts to 600volts at least 4amps...10Amp rated)
magpwr
Quote from: itsu on October 10, 2014, 03:39:11 PM
Magpwr,
looking good i guess, but i must confess that i am lost at where you are with your V6.2 or V7  :o
I am trying to replicate the original Mikmur (V1?) diagram and am slowly creating the shown A, B and C pulses which hopefully eventually drive the kacher.
Then i can continue with the Yoke setup.
Regards Itsu
hi itsu,
I am a little lost on why you wish to with the circuit diagram which i mentioned many times over it is intentionally made flawed. :'(
I have attached once more the Ruslan version which is similar to my version 6.2 of the nanopulser.Just the additional 1n4148 at the igbt driver input to prevent noise for ver 6.2.
I will attach my Nanopulser version 6.2 and version 7(5k pot->2k pot to be changed) for the last time."Please save it".
I have also attached igbt driver models review and pasted the delays which comes with it.(This is just additional info not part of device.More relevant for nanosecond driver stage)
TC4420 was used in Ruslan circuit as a guide.
Enjoykin
Thank you Itsu, T1000 and Void - much appreciated !!!!
Hi magpwr !!
You have made mistake about capacitor. On your picture is bipolar HV capacitor not electrolytic one.
It has very low ESR so it is fine part for pulsing up to 600Vrms.
On mikmur schematic he is C32 rayed 5nF/1kV
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/142507/image//
Try on ebay.ru to find some of them.
Reg !!
Self-runner from Anapa More
Sucessful replication of Roman Karnouhov Akula OU generator
http://www.youtube.com/watch?v=1i90pgjPt_0
Man has very interesting channel vids about many OU experiments.
http://www.youtube.com/channel/UC8M-dD3YGiEmzizz_6TkgDg/videos
I was looking this video long time and finally watched him last evening. I recommend you watch this vid and try experiments to catch OU EFFECT we need -  Everything is here and it is so simple you will laugh yourself into fits
Трансформатор на воздухе Видео от Akula0083  - Aircore inductor video Akula0083
http://www.youtube.com/watch?v=Fnd3W0myxjY
I am pretty disappointed in mikmur schematic because there are many errors and i am sure his schematic is pretty useless.
1.st error.
Generator on TL494 is bipolar type with poor DutyCycle and frequency tuning.
2nd. error
AFC (auto frequency control) was solved very bad and will easy roll up oscillator frequency with smallest instability. On that way you will get amplitude modulated frequency detector. How ? Role of both VD49 and VD50 diodes 1N4007 is to switch C33 capacitor from pin 5 of TL494 to ground according to signal from current transformer. So minimal  threshold is about 0.7V-0.8V for both havf-wave cycle.
Solver.
We need here aditive mixing of rectified signal from current transformer not AM modulated. We shoud track very tiny variations of current fluctuations in reactive part of circuit with help of factory calibarted current transformer and superimpose this very tiny DC offset to ramp circuit in TL494 on pin 5.  This pin is part of internal RC oscillator. This capacitor is very important. He must be NPO type - best quality made you can obtain with best dielectric and must be shunted with small RF capacitor (10pf-30pf) from "hot side" to ground. Same worth for RC oscillator resistor.
All of these is needed for great frequency stability against jamming and temperature variations. Also whole TL494 must be placed of wide ground surface and shielded because powerfull source of interferences from Katcher, "Grenade" coil and reactive bifillar coil.
Reg.
magpwr
Quote from: Enjoykin on October 10, 2014, 09:53:02 PM
Hi magpwr !!
Reg !!
hi Enjoyki,
Just picture this yoke output somewhere 150volts <250volts.
And you put 1KV capacitor which is expensive /overkill for this task merely 400volts to 600volts is needed to save space and money.
I am sorry 5nf is 0.005uf.This value is too tiny for "Energy storage" for the nanosecond pulser."This would be a failure and mikmur is wrong"
Please tell me if there is "any harm" by putting a much higher value pulse capacitor for "energy storage" meant for nanopulser.
I am not going to waste time discussing about this capacitor anymore. :-X
I hope you don't take my direct comment too seriously. :D
Thanks for the video links.
magpwr
hi everyone,
AFC(Automatic Frequency control)
is the last stage to work on for the circuit board.
Today i will be starting experimenting with AFC (Automatic frequency control) for the PWM generator.
I have previously spotted a 3.5cm...4cm toroid which a cable from 3 turns from yoke is going through the small toroid.It is around 30..35 turns for the small toroid.
"The purpose of the AFC section is to cater for the change in loading and change frequency at PWM a little from default value 27khz as an example.
Recall the value 17khz-27khz-37khz pasted in circuit diagram.
"Alot of memory work is needed" :D :D
