0 Members and 246 Guests are viewing this topic.
magpwr
Quote from: Hoppy on October 11, 2014, 04:41:01 AM
Mag,
Have you decided how to interface the nanopulser toroidal coil to the Karcher primary in versions 6.2 and 7.0?
hi Hoppy,
Do you recall the flat copper wire which was wound over the tesla coil which i mentioned 20AWG.This is one 1 of possibility and another device i previously spotted additional coil was wound side by side
with Antenna coil.
The catch is suitable toroid need to be selected for the interface between transistor and coil.Please ignore the transformer portion in my virtual experiment.
http://realstrannik.ru/media/kunena/attachments/4056/h2144e74.jpg
http://realstrannik.ru/media/kunena/attachments/3866/n1.jpeg     (Thin copper wire is trifilar -3 together)
Hoppy
Quote from: magpwr on October 11, 2014, 05:18:03 AM
hi Hoppy,
with Antenna coil.
This is similar to the Daly version. However, the additional flat copper coil windings were added by Ruslan after he demonstrated a self-runner using just the conventional Karcher coil windings. Do you see any reason why the Mikmur Karcher drive circuitry should not work, assuming that the supply to the primary coil is HV sourced from the yoke 28 turn secondary, as per your edit?
itsu
Quote from: magpwr on October 10, 2014, 09:08:34 PM
hi itsu,
I am a little lost on why you wish to with the circuit diagram which i mentioned many times over it is intentionally made flawed. :'(
Magpwr,
i do not share your idea about people "intentionally changing diagrams".
Offcourse there could be some mistakes, but up till now most of your "bugs" i have proven to be not true, like
the 100 Ohms resistors at the MOSFET drivers, the VD4 which suppose to blow up the 74xx chips, and the need for
using 74HCxx chips instead of plain 74xx's  (ok, they work better).
So i will try to get the original Mikmur diagram working instead of following every change that is being made by people including Ruslan himselve.
I know, i will find out eventually, but he, thats just me.
Please try to get it working your way, we should be able to get it working some day...........if it is possible at all that is.
Thanks,  regards Itsu
magpwr
Quote from: Hoppy on October 11, 2014, 05:44:02 AM
hi Hoppy,
That was  the first possibility initially but i have already tried to superimpose negative or positive pulse to the transistor base while the tesla coil(old existing coil of different spec) is resonating.No other waveform was observed on scope by placing probe nearby.
So we are left with 2 better possibility as mentioned my me earlier.
There was this article a very very long document which i just read yesterday from the time of Nicola Tesla as found in the Russian forum after google translation.
I think i found the missing stuff where or how all this kapanadze stuff possibility really started from."Please do search for it in Russian forum and translate base on yesterday posting which i spotted.I don't know why this tesla document was not seen elsewhere in the internet" Google translation do have limitation after certain pages it remains Russian.So take that reminder content and paste back into google translate. :)
Long story short -Tesla found that applying 1/10 of a microsecond pulse(~100ns ) he noted the normal tesla coil would produced electrical charge/electrostatic/electrodynamics  around the device during the time when he was about to start work on "ether"."Before this experiment of his, he research into a unknown effect-Using tesla coil by someone at a university where it is reported that even the door knob became charged to shock until the device is switched off.Tesla found something to replicate this effect over and over with the nanosecond technology of his time"
Recall the video where Ruslan placed his hand over the antenna.There should be a tingling sensation present(as also mentioned by Tesla) on the hand if place near antenna.This is not produced by spark.
Gas was also mentioned by Tesla quite similar to Akula in the pdf which is related to the tesla coil tuning video.
It's all coming back to Tesla.
magpwr
Quote from: itsu on October 11, 2014, 07:27:15 AM
Magpwr,
hi itsu,
No worries i will carry out experimenting my own way.
I have decoded the working of this device to the best abilities as i possibly can to assist you guys and most importantly prove this device is not fake since the inner working was not understood at all and blind replication was carried out previously by keen builders for the last few years.
There is nothing more for me  to add  at this point.All that is left is experiment and tuning.
Good luck.
