0 Members and 348 Guests are viewing this topic.
GeoFusion
Hi there all
Some Vasmus updates, this will also let you see that power comes from ground , using the amp clamp and see the amps flow.
removing the ground kills the circuit as how Ruslan does in one of the latest vids. ;) some hints guyz.
Vasmus11
https://www.youtube.com/watch?v=g-aCBelO_0c#t=578
2nd part
https://www.youtube.com/watch?v=ub71Ea5ppio#t=22
Remember when you connect a ground pin to earth and use a one phase to ground you will have some power.
that is why the ruslan/akula device needs ground.
There are some of akula that don't need ground but the ground is needed as it feeds and somehow returns too.
Enjoykin
Anapa More
Сборка установки серия 3
http://www.youtube.com/watch?v=hg-hob78rgA
Намотка качера, и размещение на доске всех компонентов
Первое включение и проверка частоты ТТ, Частота не совпала с резонансом "Гранаты" нужно настраивать, в моем случае сматывать вторичку и переделать первичку.
d3x0r
https://www.youtube.com/watch?v=lTwq_EbYy7U
at the end he's talking about resonance... of the cuff coil and the kacher... but what about this "grenade" coil?
He makes a accurate description of how to wind and measurements of his... incliding inductance around 240-250 uH
need to find some kinda russian sesame street :)
NickZ
  Thanks for the link to Ruslan's new video showing the grenade winding set up.
  I don't see the two final layers of 12, 12 turns in the video, on the end of the 48,48, 24,24, 12,12 turns that are shown in the Kapanadze coil diagram. So, I think that he just uses the first 4 layers, (48,48, 24, 24, without the last two layers of 12,12 turns.
  His smaller (resonator) coil on the grenade is not wound with 25, 25 turns, but possibly 12, 12 turns, instead.  Or, possibly 25, 12, 12, turns or so.
  What do you think...
  I've finished my "grenade" coil, and will proceed to connect it up to the 20 plus turns secondary coil of the yoke.
  The 12,12 turn resonator air coil will be connected to the yoke 3 turn coil.
And the Kacher, ferrite rod, and antenna will be connect up, as well.
joel321
Mostly all coils...I even saw a coil coming out of a coil connected to the air.
I don't believe in magic (you power those capacitors with a 9v battery that powered the coils...), but this is very well shown it is mostly true.
In the end when you mangled up all, nice....
