0 Members and 52 Guests are viewing this topic.
GeoFusion
Quote from: Hoppy on October 13, 2014, 12:22:08 PM
Nice grenade build Geo. Its good to see that you are also shooting for a self-runner.  ;)
Hi Hoppy.
Thnx, yes alot of effort in building and understanding it but will show what my results are soon.
I am uploading a vid on this, all about the windings and diameters of wire and some more specs for better view on the coiling.
and later the rest of coiling which I didn't place still , but will come in the 2nd vid.
and finally to see it work.
I'm happy to see everyone working on it, experimenting and trying it out the hard way will let us all know answers. it helps.
Cheerz man.
NickZ
  Hoppy:
  I'm saying that there should be 12, 12, turns on the resonator (inductor) because that is what both Ruslan and Akula have been using, as far as I can tell.
  Some diagrams are showing 25, 25 turns, for that induction coil. But, nobody is using two layers of 25 turns. And Ruslan is now showing 20 turns, single layer for that coil. It probably depends on what the input voltage is though.
  Here's a pic of my "Grenade" coil. 48,48, 24,24, 12, 12, turns, and the resonator (inductor coil) is 12, 12, turns. It may not be a work of art, as it's mostly all recycled materials, but it may work just as well. More to come, soon.
  Good to see some pics from Geo also, hopefully he can show it working soon.
Hoppy
Quote from: NickZ on October 13, 2014, 01:24:39 PM
  Hoppy:
Thanks Nick. Yes, it could be to do with the input voltage.
d3x0r
I thought the outside was 20+20 for a total of 40... slightly less than the 48 of the under.
I don't see a single layer coil... 1) the cuffed coil is the same height as the 2x 24 part of the grenade... 2) from the inner side, it really looks like 2 thicknesses of wire....
I increased mine to about 60, so the inductance of that is the same as my grenade.  one would think as in transformers that you can get more voltage out if you use fewer windings there.. I was trying to match resonances; but I don't think that's as important throughout the system.  think I used slightly lower gauge wire on that coil too, and have mulitple tap points into it now....
I don't know of a reference that would be for 12+12... it would seem to be 'as much as covers the first two exposed layers' and 2 layers...
one layer could work, but then you'd need a bigger capacitance to get the resonance at the same frequency; would that imply more current flowing overall?  would that be at a higher or lower reactance?
It would seem to me, interpreting motions and the 5 or 6 words I'm getting to know; that maybe the cuff is supposed to be a capacitive driver... as if that's part of the 'low self inductance and high capacitance' mentioned in telsa court notes....
Hoppy
Itsu @ all,
The waveform attached is taken between base and emitter of the Karcher transistor VT8. The pulse is just on 50nS with some ringing which is probably due to the imperfect bread board construction. I found that the push-pull transistor drivers did not work well, so I used mosfet drivers (TC4127). Diodes 1N4148 between mosfet inputs and ground did slightly reduce the ringing. Also, R13 (1K2) & R12 (840R) were transposed.
