0 Members and 529 Guests are viewing this topic.
NickZ
 There are different sizes of the Russian yokes, but the first one that Akula used did not work, (second picture below).
  I've been using yokes that is about 3 inches wide, but I also have some smaller ones.
  Here is a picture of my yoke, and a picture of the one that did not work for Akula.
magpwr
Quote from: NickZ on October 14, 2014, 11:17:15 AM
hi Nickz or anyone,
I have attached a photo of Yoke with 3 turns.Please advise us if the 3 turns suppose to be at Point A or Point B?
I merely recall from Geofusion roundcore project that yoke half was isolated by tape.But i am not sure if Akula version is isolated a not which can be discovered later on based on the one which give highest output.
NickZ
  The three turn coil is placed at your point B, right at the center of one of the 1/2 yoke cores. This is the point where there is little induction, so I don't know why they want to place the 3 turn coil there, instead of at the ends of the primary coils.
  Refer to Geo's diagram to wind the rest of the coils on your yoke.
  I don't think that neither the clips or the tape between the yoke core half are actually doing anything one way or the other.
  But, I followed the advice and I did place tape to isolate the halves.
  Some of the clips are magnetic (iron), and some are not.
  I didn't see any difference in using any of the clips, or not using them, and taping the two halves together instead. No difference, as I got the same output power from my device.
Jeg
Quote from: NickZ on October 14, 2014, 12:16:08 PM
Yeap. I report the same. Didn't see any noticeable difference.
GeoFusion
magpwr:
Yes at point B. Needs to be opposite side of the pulse primary coil  side  that is connected to mosfets and TL 494 circuit.
Nick and Jeg:
correct guyz ,The yoke needs to be wound as how I do the same way how Ruslan does.
I simply use the iron clips of the yoke but isolated, can be done without the clips but if you use them it will hold the two halves very good and you will be sure they wont create  gaps that changes the frequency all the times. it manages to hold it at one state.  , did also some with and without tape isolation between halves,
But one with tape isolation  is to gain the Chaotic mode for extreme drive ( those where tests ), it generates a high drive moment , but is very unstable most of time.
but for this Ruslan generator It should drive in normal mode but slightly higher frequency while tuning to reach resonance with the cap that willl be placed in series with the 3 winds and bifilar inductor on the grenade.
Cheerz
