0 Members and 220 Guests are viewing this topic.
NickZ
  Guys please look at the jumper connection between the 28 turn coil and the 3 turn coil, which are BOTH connected to the earth ground. This MAY be important. IF you want to replicate what both Ruslan and Akula are showing on their Akula second video replication diagrams. As both of these coils are connected together, and then you need to tune them with the proper caps for YOUR circuit. They may not be the same value caps that are shown on their circuits. Using the right caps is everything, or you won't get much brightness from your bulbs. As you've seen...
   My yoke alone can light 7 100 watt bulbs by itself. But, the fets fry even without any load from the bulbs. So, I'm still looking into this issue.
  I don't see the caotic mode, just the normal one, now. Ringing is minimal, as well.
  From what I gather, the 3 turn coil needs to be in sinc with it's resonator coil (12, 12, (or 25, 25) turns air coil on the left (input) side of the grenade. Not with the bigger output coil (48, 48, etz).  But like on Akula's first video device, where he connects the 3 turn coil through the tuning cap to the 12 turn resonator on the air coil.
  Itsu:  I previously had placed the Joule Ringer core (with NO circuit) on top of the yoke, as I could see that the JR would produce HV, (I got shocked) just from the yokes secondary coil, by induction, to the JR with no wired connection between them. Then just connected the end of the JR secondary coil to the 28 turn coil, but at the bulbs. This should sink the yoke's secondary coil frequency to the JR HV secondary coil, but like you observed, the bulbs where only just lightly brighter, or not really any brighter.
But, the bulbs do get a little brighter when connecting the JR to the 12v battery with it's own oscillator circuit then to the yoke's output at the bulbs, as can be expected. But, still not really anything to write home about. Just to you guys... Ha!
magpwr
Quote from: Void on October 15, 2014, 12:16:19 PM
Hi magpwr. I think maybe you mean this video? This is not the original, but Wesley's translation of it:
https://www.youtube.com/watch?v=PPHipGkfSAY
All the best...
hi Void,
Thank you for finding the link.
I finally 100% know now that the old video of Akula was actually talking about "harmonics" which was not mentioned in translated video or not mentioned by Akula back then. :)
Take note guys Akula mentioned if this two frequency is not aligned it won't work.
Void
Quote from: T-1000 on October 15, 2014, 06:20:03 PM
I just finished listening teamspeak conference
Hi T-1000. Thanks very much for that. This helps to support a few things I have been seeing
in my own experiments. It really appears we need to let go of some conventional notions and start looking at
this quite differently. :) Scope probes can be a hindrance as well. Why? Because whether the scope is electrically
isolated from earth ground or not, the scope ground clip can still act as an AC ground to some extent and alter the circuit
behavior depending on where the scope ground clip is connected. This can potentially give very misleading measurements.
The circuit may behave quite different again as soon as you unclip the scope ground clip. Conventional 'resonances' move around
all over the place based on what other components are connected or are in close proximity as well. That is normal,
but I don't think these are the types of 'resonances' and 'harmonics' that are being referred to anyway. :)
All the best...
d3x0r
Working Theory Of Operation For Meyer's Voltage Intensifier Circuit. 8-14-14 Gries Petty Research.:.
https://www.youtube.com/watch?v=4kLFFkAOARI
I know this seems entirely disrelated; but the same resonant effect within the wire is applied .....
Enjoykin
Quote from: Void on October 15, 2014, 09:04:32 AM
Hi Enjoykin. Thanks for that.
Many of the people here can not speak Russian.
Any chance you can provide a short summary here of the important points in English? :)
All the best...
Hi Void
Ruslan Kulabuhov interview will be soon on freeenergyinfio channel in english. It is big 108 min.
Reg. Enjoykin
