0 Members and 23 Guests are viewing this topic.
itsu
Quote from: MenofFather on October 16, 2014, 01:57:57 AM
Itsu, thanks, were conected wire 1 and 2?
Wire 1 conected to mosfet drain?
MenofFather,
correct, wire 1 is attached to the drain of the MOSFET, wire 2 to the other side of the Schottky diode.
Basically, the wires 1 and 2 are across (parallel to) the Schottky diode.
Regards Itsu
itsu
Quote from: T-1000 on October 15, 2014, 06:20:03 PM
2) The Grenade coil - It is receiver wound on tube of 50mm diameter with length of ~21cm length, full winding on it for layer forward and continue with second layer to same direction, then divide its length by 2, put the same cable from the end of 2nd layer until middle and wind into opposite direction direction until end then continue with second layer to same direction, then again divide by 2 and put the wire until middle from end of previous coil and wind into opposite again until end (the last half is in same direction as longest bottom) then continue layer on same direction. Then put wire across top coil and put inside of tube then make exiting under begining of coil. The total length of wire = 1/4 of resonant frequency. Also the inductance is minimal (microH range). The ground is also connected to the wire exiting from top of the coil and should be completely separate to avoid any noise as device is really sensitive to it.
T-1000,
do you mean with the part in bold that the last layer (2x 12) is in the same direction as the first layer (2x 48), meaning CCW?
If so, i doubt that as this below picture clearly shows its also CW as the middle layer (2x 24).
Regards Itsu
MenofFather
Itsu, did you see what your nanosecond pulse ferite ring and Ruslan is wound different? So Ruslan probarly not get nanosecond pulses! He get 200 volts 300 ns pulses or something similar. Right?
itsu
Quote from: MenofFather on October 16, 2014, 06:03:51 AM
MenofFather,
i do not see any difference in the connections between the two drawings.
Only the dots are on the other sides, but as both are, that does not have any effect.
Regards Itsu
Void
Quote from: Enjoykin on October 15, 2014, 11:00:31 PM
Hi Void
Ruslan Kulabuhov interview will be soon on freeenergyinfio channel in english. It is big 108 min.
Reg. Enjoykin
Thanks!
