0 Members and 178 Guests are viewing this topic.
Jeg
Quote from: magpwr on October 16, 2014, 12:14:37 PM
hi everyone,
Harmonics solved
Well done Mag! Nice and simple method. Is it possible to check something more? Ruslan said the low freq is the 1/100th of the resonant freq of grenade. If this is 1.7Mhz, then low freq would be 17khz. Can you check how they appear both on your scope?
magpwr
Quote from: Jeg on October 16, 2014, 12:29:57 PM
hi Jeg,
Before i sleep.
I have done a quick test base on what you said.1.7Mhz and 1.7Mhz.
Result-Although i can see the alignment from top to bottom (green as shown in previous attachment)but the side of the 1.7Mhz is sticking out so this part is not aligned.
Don't you have a digital scope to try?
By the way recall Akula mentioned it's pointless to go below 18khz if it's a air coil."Base on my <3 or 4 weeks old posting"
That's all for today.
Void
Quote from: Jeg on October 16, 2014, 11:50:58 AM
Hi Void
Yes he means this 25+25 inductor. In an other Ruslan's post on realstrunik he spoke about 11 meters of cable when his grenade at the time was about 33meters. So 1/3 wavelength will have the same result.
Hi Jeg. Thanks for the reply. Ruslan stated his grenade coil was 37.5m for that coil I believe.
37.5 / 2 = 18.75m. I don't think Ruslan has mentioned anything about using a 1/3 ratio.
Some things Ruslan has said previously appear to be changing recently however. It does seem
that he is now saying the bifilar primary winding wire length on the grenade coil should be 1/2
the length of the grenade coil winding. Let's see if T-1000 or another Russian speaker can clarify about this. :)
All the best...
itsu
Quote from: MenofFather on October 16, 2014, 11:32:23 AM
In other drawing.
Itsu, now you see diference betwen your conection and Ruslan?
Hi MenofFather,
yes, i see what you mean, but how you found out thats the way Ruslan has connected it from that small picture is beyond me.
Regards Itsu
itsu
I am now able to conclude on how to derive either the resonance frequency of the multi layer coil or obtain the needed frequency for the tesla coil.
But the easy approach is to first know your resonance frequency of the multilayer coil eg:26.1khz,27khz or something that fits within this range 18khz....37khz
But but but, the multi layer coil (2x 48, 2x 24, 2x 12) does not resonante at  range 18khz....37khz, thats the 2x 25 turn pickup coil with the 0.47uF
capacitor in series!
My  multi layer coil (2x 48, 2x 24, 2x 12) resonates (without any capacitor attached) at severall points starting at 950KHz - 4MHz.
And looking at your screenshot, i see a small high frequency sine wave of about 1.620MHz, and a bigger sine wave half of the frequency,
meaning 810KHz, not 27KHz or am i missing something?
Regards Itsu
