0 Members and 49 Guests are viewing this topic.
MenofFather
Quote from: itsu on October 16, 2014, 01:05:44 PM
Hi MenofFather,
yes, i see what you mean, but how you found out thats the way Ruslan has connected it from that small picture is beyond me.
Regards Itsu
Jeg
Quote from: Void on October 16, 2014, 12:54:23 PM
Hi Jeg. Thanks for the reply. Ruslan stated his grenade coil was 37.5m for that coil I believe.
37.5 / 2 = 18.75m. I don't think Ruslan has mentioned anything about using a 1/3 ratio.
Some things Ruslan has said previously appear to be changing recently however. It does seem
that he is now saying the bifilar primary winding wire length on the grenade coil should be 1/2
the length of the grenade coil winding. Let's see if T-1000 or another Russian speaker can clarify about this. :)
All the best...
I remember that he was speaking about a grenade of 33 m wavelength. On the other hand he speaks about a diameter of 5cm which results a 32.2m wavelength in this specific form of 48-24-12. Close to 33 and 11.
GeoFusion
Hi guyz.
   magpwr,
Well done on the part of Resonance and understanding the Harmonics on frequencies for the Tesla coil and grenade coil. This is it.
This will be the example that everyone needs to follow and this has to be achieved in order for the device to work and most of other devices too. Synchronization
T-1000:
Thnks for the conference notes, they help alot. Got most of the answers from Realstrannik.
Hoppy,
yes the  PVC I use  is 50mm diameter (5cm)  both Tesla and grenade.
TheGrenade coiling length is ~21cm long. ( length seen from above)
telsa is about 15cm long.
But any length can be adjusted, just need to find the right frequency , harmonics and sync.
   Void:
well for what I can tell is the  winding of the Bifilar primary on grenade (x2 25) is that bifilar is same direction wound as the 2x 24 layer of  grenade, CW. Yet how you layer them ontop of eachother is different though, see the schematic as we all have it.  It can be seen that it it's 1/2 of the grenade too. about ~ 10.5 cm length
Btw guyz If someone does not want to rewind the grenade to exactly 37.5 meters turned or has it different (2 MHz frequency Kacher) Here is a table for calculating frequency Kacher, changing the length of the grenade.
https://docs.google.com/spreadsheets/d/1_0vR-jPQQMqBwIGozntELrAqh8ydLJ_0thRTARzevFk/edit#gid=0
Keep it up guyz, this is progressing at a beautiful rate.
  Cheerz.
Jeg
Quote from: magpwr on October 16, 2014, 12:51:31 PM
hi Jeg,
Before i sleep.
I have done a quick test base on what you said.1.7Mhz and 1.7Mhz.
Result-Although i can see the alignment from top to bottom (green as shown in previous attachment)but the side of the 1.7Mhz is sticking out so this part is not aligned.
Don't you have a digital scope to try?
By the way recall Akula mentioned it's pointless to go below 18khz if it's a air coil."Base on my <3 or 4 weeks old posting"
That's all for today.
Nope. It is an analog scope.
I don't see any particular reason for not going even to 5Khz. The lower the frequency the longer the current pulse cycle, the more the discharges you can do per cycle.
I would also like to thank T1000 for translating, and all of you guys for giving your best to this fascinating project.
d3x0r
Experimented with measuring the length of the grenade with a signal generator...
found resonances with scope probes connected directly at about 7Mhz... Removed the scope probes, and moved them instead to a coil around the signal generator signal conductor, so it's a current measurement on the signal generator otuput; so I'm really erading the signal, but get enough feedback at resonance to the drive that it shows up.... re-tuning found resonance around 6.24Mhz, which is like 48m which is about what I have using core measurements and increasing radii ... at that point, a square wave ends up with lots of parallel harmonics.  I was driving at a frequency lower than that, but with a shorter duty cycle pulse signal.... so was a combination of tuning the base freqneuency and then the pulse width to find the best harmonics on a FFT math function on my scope....
(2 3/8" core/ 60mm)  ... figured 1/8" wire steps which I guess is a little wide
64/32/16
my kacher is 37m I guess... 200 turns 60mm ... I guess I need another 60 turns to get to 48m ...
