0 Members and 75 Guests are viewing this topic.
MenofFather
QuoteBut but but, the multi layer coil (2x 48, 2x 24, 2x 12) does not resonante at  range 18khz....37khz, thats the 2x 25 turn pickup coil with the 0.47uF
capacitor in series!
Yes. That capasitor in series with multi layer coil is not resonase capasitor, it is coupling capasitor.[/size]
QuoteMy  multi layer coil (2x 48, 2x 24, 2x 12) resonates (without any capacitor attached) at severall points starting at 950KHz - 4MHz.
Only in this two points (I get only on 900 kHz and 4 MHz)?
MenofFather
QuoteI swapped the nano-pulser little toroid secondary leads, and now indeed the nano-pulse at 150V dc input is only 330Vpp instead of 1KV, but
also about 1/3 wider at 50ns instead of 15ns.
Well done! Try inreace pulse lengh going to transistor gate. To get 100-300 ns pulse.
And inductor (bifilar coil, of two layers) must be grounded. And it must be on top coaxial cable, better maybe mount tube on coaxial cable and then wound inductor.
You can try that setup:
Void
Quote from: d3x0r on October 16, 2014, 11:32:29 PM
I'm not sure why it's not closer to 0... 1/2 of the turns is slightly wider in diamter for slightly more inductance, plus the 3rd layer being 1/2 again that much is also larger... which would be more towards zero than -3/4 would be...
260 turns at 6cm for 52cm length (2mm wire maybe) is 438uH ... same coil at 1/8" winds (82cm) is 283uH which is just the 49m wire wrapped as a [size=78%]solenoid... I thought the reverse windings subtracted inductance...[/size]
was trying to find a calculator for inductance of a straight wire... like if 49m isn't coiled in any way, what's it's inductance?  Is the real inductance of the coil +0 from the wire's inductance itself?
49m in 1 loop (15m diameter) is 32.8uH ... in theory...
Hi d3x0r. If we just look at one equal length layer of two windings which are wound all in the same direction, then
that will be phase additive windings, so the total inductance will increase rather than cancel.  The next two
layers are wound in the opposite direction from the bottom two layers so there will be some counteraction
there with the bottom two layers, but there will still be an overall total inductance amount since the bottom two layers
have more turns than the total of the above layers. If you balanced the total inductance amount of
the higher four opposing wound layers with the inductance of the bottom two layers you could end up with
close to 0 inductance from wire end to wire end, but that is not what Ruslan showed in his video anyway.
It appears that total overall inductance cancellation wasn't the goal based on what Ruslan showed.
Coils have a high degree of self inductance due to the magnetic interaction between adjacent turns in the coil,
so it is not comparable to the inductance of a straight wire if the windings in the coil are wound phase additive.
If you wind a two layer coil with the two layers wound in opposite directions you will get a resulting
low inductance since the two layers are wound phase cancelling. How low the inductance is depends on
how evenly matched the two opposing windings are. The more evenly matched the two windings are the more
cancellation will occur. Ruslan showing that he had roughly 240 to 250 uH in one of his grenade coils
does seem to indicate that his goal was not comlpete inductance cancellation, although as I said
the '48' turn bottom two layers inductance will be opposed by the shorter layers above that are wound in the
opposite direction, so the total inductance of the grenade coil will be a fair bit less than you would
get if all layers were wound in the same direction.
All the best...
magpwr
Quote from: Acca on October 16, 2014, 11:22:43 PM
Roman  (Akula0083) has a new Tesla power generator.. 20 Watt free power generator.
Look in HD and it's great !!
https://www.youtube.com/watch?v=awy9OgRd-D8
Acca..
hi Acca,
Thanks for providing this video link.
Everyone, i do have good news for you since this low power device was sold to China.
I do have alternate view which it would spell good news for us all related to the current device we are working on.
Recall the video of Akula where he mentioned something like "frequency of the land" which was giving me headache because it was just one of the last riddles i feel weeks back it needs to be solved.
Long story short -Since this recent low power device was sold to China and obviously it will be in land of China.What i am trying to say here it doesn't matter now what "frequency of the land" means. :D :D :D
Isn't this considered good news since now we know this device can be placed on any land-running at optimal a not it doesn't matter as long it self run. :D
To me as long you got metal water pipe which was dug in Earth or common metal "house heater" as seen in Ruslan or SR193 video is good enough.But i am unable to tell if you stick a thin pole in wet soil to get something out this part i don't know on how to advise for the rest since we are only at the discovery stage.
For me although i am living in high rise apartment my water pipe is 100% connected to the earth below one way or another in a network of water pipe large or small which covers the entire island. :D
Please wait out for my next post 1 or 2 hours later-related to my latest findings as generated in my head "with no riddles" but base on pure science.
Hint-We are approaching the end to crack this device."It's like breaking the magician code episode" :D :D :D
d3x0r
Quote from: Void on October 17, 2014, 06:21:35 AM
.... Ruslan showing that he had roughly 240 to 250 uH in one of his grenade coils
does seem to indicate that his goal was not compete inductance cancellation, although as I said
All the best...
Right; I concur that measurements indicate 240... itsu I think was down at 170?  Mine's 266....
I guess there's a factor of turns * turns in there too... so 64 is a LOT more than 32....
like to go from 220 to 266 was really only 6 turns... on top of already 48 hmm just wondering I guess it adds up to more than 0.
and then not Re quote....
https://www.youtube.com/watch?v=_5CHOn7gi-g
I think I blew up my 555's output.  I changed the transistor for a mosfet because I figured maybe I wasn't really supplying enough current... and hence the spike.  I got the same puls-y sort of spike with a mosfet... ended up with multiple back ringings at about 3x 45Khz.... still was unable to get a 45khz resonant wave... it flattens out and becomes more spikey with a higher current driver....
Had about 30 seconds runtime on 68kuF 60V Led... recorded but not published yet... I think I can do better... but then I was adjusting my 555 and stopped getting output; either I killed the irfp250 or the 555, which only has .5V output now.. *shrug*
