0 Members and 113 Guests are viewing this topic.
MenofFather
Quote from: magpwr on October 17, 2014, 04:23:06 PM
hi itsu and MenofFather,
This video is unique.Please watch scope in video.Time to resume sleep cycle.
It seems using tesla coil with multilayer coil he is able to light bulb dimly with no nanosecond generator or yoke."It's like semi power on ,recall just the fan came on in Ruslan video"
https://yadi.sk/i/stpsTAWhbwY9H
Need help to translate key points to English.
This video is nothing speshal.
URFA
magpwr
hi itsu and everyone else,
Today i started winding my 1st Kapanadze Grenade coil.
I have made a very important discovery while winding the turns and base on recent Ruslan video.
I have attached Ruslan version and my version.
My coil is closely following Ruslan after i discovered the winding for the 1st layer needs to be 60 turns at least in order to get 25 turns exposed which falls within 10cm as explain in the attachment and in Ruslan video.
I have put my winding figures in attachment for reference but i don't expect anyone to follow unless extra kapanadze coil is needed during testing purpose.
For more details please refer to recent Ruslan video in youtube.
Design tips-This my design as attached all  Tesla coil and Kapanadze grenade coil was done on 1 pvc pipe with just 1 small hole in the middle.
20AWG Tesla coil is protected by few layers of newspaper while working on kapanadze coil. :D
Resonance of tesla coil at the point of winding is 1.61Mhz,this will be amended later on.
Can anyone recomend any online link on where to get the pvc pipe clamp holder with short stand\pole as seen in Ruslan\Akula video maybe.
Jeg
Enjoykin and  Urfa thanks a lot for the drawings and Ruslan's video. I hope that Wesley or someone else will translate this in English for us. I feel like a starving man without teeth, where his Russian friends give him a solid rock well cooked steak to eat!!! :D
I have some questions and eventually by the time i hope that will be answered.
1. At Enjoykin's second drawing of previous page (Ruslan's drawing), at Katcher side there is an open connection between base and 1K pot. Why is that? Is it a waiting for synchronization? Does it need synchronization at the end or it is not necessary?
2. Does anyone can understand from video what is ruslan's katcher circuit?
3. Ruslan during video tunes his katcher at 3.1MHz with out the antenna connected. When we connect the antenna part won't that frequency become lower ???
I started to like Ruslan as he seems very honest with good intentions. He seems that he really wants to help.
Wow. Thanks again
Ps. Mag I also can't find these PVC supports in my area so I made some of wood.
itsu
Looking great magpwr, i don't think the exact number of turns or exposed wire is important,
just have the tuning right and you should be able to get it working.
I have removed my coax windings around the 2x 25 turn coil and wrapped 25 turns of 1.5mm² solid copper wire instead.
The inductance of the 2x 25 turn coil stayed the same 87uH but the resonance of this coil in combination with the 0.47uF cap
went from 26.5KHz to 47KHz!!??.
This caused the nano pulser repetition frequency also to go up to that frequency as it is synced with the TL494, which was to much
and things (DSR diode, little toroid) were getting hot very fast also because the impedance of this extra coil is not the expected 50 Ohm.
By adding another 0.47uF cap parallel to the first one, the resonance frequency went down to 32KHz so this capacitor is not ONLY a coupling cap
it also influences heavely the resonance frequency of the 2x 25 turn coil.
I have no explaination why the resonance frequency went up with the same inductance, as the extra capacitance from this extra coil should have
caused it to go down in frequency,  Right?.
But this in combination with the extra 0.47uF cap parallel is dampening the resonance heavely and the max pp voltage went from 160V to around 90V,
(or are we talking mutual transformer coupling losses here?).
So i don't think this is the correct route (the extra coil) to follow to get the nano-pulse delivered to the grenade.
Meanwhile i will be making a shorter Kacher secondary coil which should be self resonating (when connected to the antenna coil) on a higher frequency (2.3MHz).
Regards itsu.
