0 Members and 99 Guests are viewing this topic.
Jeg
Quote from: itsu on October 18, 2014, 06:36:52 AM
I have no explanation why the resonance frequency went up with the same inductance, as the extra capacitance from this extra coil should have
caused it to go down in frequency,  Right?.
Dear Itsu
i think there is a mess between the harmonics that are involved before and after. Does your 25+25 coil have a matched wavelength with the grenade? Does your added 25 coax turns have a wavelength relationship with your grenade? Your answer lays somewhere there.
Jeg
Guys just a small tip for calculating your coils length according to a specific set of desired harmonics.
At the attached image there is the portion of the 3T circuit. As we see this include two coils in series with a cap. One coil of 25+25 and another of 3T. When we falsely say that this 25+25 turns coil has to be in a wavelength relation with the grenade, in reality we mean the whole cable which is connected at the legs of the capacitor. This includes both coils because they are connected in series, including the connection wires between them. Then, we are talking about matching. There are some ways for breaking this line like introducing one more capacitor on the other side of the existed cap. between the two coils. But there is no reason to do it as 3T are very short length and doesn't affect our calculations. If the 3 turns were instead 2000Turns, then this coil would be far longer than the 32-37 meters of the grenade, and so an other cap or diode should be included to separate the two coils, so to response without the one affecting the other.
magpwr
Looking great magpwr, i don't think the exact number of turns or exposed wire is important,
just have the tuning right and you should be able to get it working.
I have removed my coax windings around the 2x 25 turn coil and wrapped 25 turns of 1.5mm² solid copper wire instead.
The inductance of the 2x 25 turn coil stayed the same 87uH but the resonance of this coil in combination with the 0.47uF cap
went from 26.5KHz to 47KHz!!??.
This caused the nano pulser repetition frequency also to go up to that frequency as it is synced with the TL494, which was to much
and things (DSR diode, little toroid) were getting hot very fast also because the impedance of this extra coil is not the expected 50 Ohm.
By adding another 0.47uF cap parallel to the first one, the resonance frequency went down to 32KHz so this capacitor is not ONLY a coupling cap
it also influences heavely the resonance frequency of the 2x 25 turn coil.
But this in combination with the extra 0.47uF cap parallel is dampening the resonance heavely and the max pp voltage went from 160V to around 90V,
(or are we talking mutual transformer coupling losses here?).
So i don't think this is the correct route (the extra coil) to follow to get the nano-pulse delivered to the grenade.
Meanwhile i will be making a shorter Kacher secondary coil which should be self resonating (when connected to the antenna coil) on a higher frequency (2.3MHz).
Regards itsu.
hi itsu,
Thanks for reporting your latest findings.Interesting finding indeed.
If you take a look at the older version of Akula at the yoke winding.I can't help noticing/keep reminding myself there is 3 or turns(around 4mm.. 6mm sq) which is also connected to the microwave capacitor in series.
Now if you take a look at the typical microwave capacitor it's typical\common rating is also 2000volts and comes with value 0.8uf ...1.8uf similar to current Ruslan 0.47uf 2000vdc WIMA capacitor.Since he is typically using 2 of this 0.47uf HV capacitor in parallel.The nearest value would be around 1uf 2000volts.
Why such a high value eg:2000volts used for the latest device is still a mystery to me taking into account one of the Ruslan video where i previously extracted the peaking at 27khz for everyone to see.
Because in that video although he was using 24volts supply instead of 12volts.The vpp voltage observe as per the probe in video which was connected to the 0.47uf capacitor is merely 16volts.
But that was not the self run mode i think for that video.He merely showed the sine-wave across the capacitor which is useful.
If you observe carefully there is no nanosecond generator mentioned in circuit diagram containing 2SC5200 even though i have spotted the circuit many times.
This part is conceal or hidden from everyone.
The primary reason why i made a move to purchase 20uf 400volts PIO capacitor (sold as matching pairs)because it is design to release energy much better than the electrolytic capacitor in the 400volts range.If the energy is released faster then the peak of the nanosecond pulse would in theory will also be higher.
Interesting thing to note nanosecond pulse does not discharge the capacitor 100% all in one pulse.I can tell you this because i was using the variable hv voltage generator(Prototype) as found in my youtube channel and the led light does not come on often while nanosecond pulse is being generated.In another words nanosecond pulsing doesn't consume alot of current.
After the 100uH,100uH transformer was presented in the latest Ruslan video.I would have exclude this transformer from my previous suspicion for possible component for nanosecond pulse injection.
The only area i think left is the flat wire wound across tesla coil or another area at the 3 turns area with the 2000volts capacitor.
This is my latest theory this device is likely self running around 20KV..40KV.
This is my Justification below-
We know that the existing tesla coil with 12volts is generating around 2KV...4kV and 24volts as mentioned by Ruslan is generating around 8KV.(Big difference in output from 12volts to 24volts)
Just picture this while tesla coil is running in sync with eg:27khz from multilayer coil maybe sync via antenna as well upon powering on.I have attached picture below for clarity.
If tesla coil is already generating <10KV while in operation then there is around 1KV to 2KV nanosecond pulse injection at the outer layer of tesla coil.
If this 1KV to 2KV nanosecond pulse is stepped up via the tesla coil won't the tesla coil becomes super charged at around 20KV to 40KV at every positive peak cycle eg:27kz  ( tolerance +/- 10khz in worst case)
If this is considered a long shot.Then i would suggest you do a search on NST powered tesla coil.Remember NST is already generating 3KV to 10KV for typical unit.Then it is further stepped via tesla coil.
If you take a look at those random videos NST powered tesla coil and look at the estimated length of spark to justify my above explanation.
Reading all the recent Tesla note as found in Russian forum.There is important part which i recall as mentioned by Tesla himself with the nano technology of his time  before fully commencing into some "ether" related project back then.
That is RF emission needs to be suppressed as much as possible,it needs to be low.There was also mention of  harmonics 10khz...20khz something related to Earth.
Telsa also mentioned room or things around room is getting charged besides reporting the tinging sensation something like on his hand.
I have played around with ionizer before.I know that by placing hand/finger near the pins you should able to feel something like breeze or ion breeze which produce the similar tinging sensation.
If you take a closer look at the waveform below which is in sync at 60th harmonics of 27khz.
If we trigger nanopulse at positive peak of 27khz then let say we inject nanosecond pulse at the outer of the tesla coil which so happen to be at the negative peak cycle.
The result would likely be a powerful negative ionizer.I can't confirm this until i get to feel the cool breeze on antenna similar to typical negative ionizer.
This part is beyond my capability at the moment since i do not know the relationship between negative ions and the multi layer coil at the 25 turns.
I have copied and past here to show everyone the difference between positive ions and negative ions
By nature, every atom is electrically neutral.
Each atom wants to have a full shell of electrons, but some atoms have a very incomplete shell, so they strive to get more electrons.
When an atom of this nature bonds with another - among other possibilities - it may gain, or "steal" electrons from another atom to make up the lack of electrons in their own shell.
A positive ion is simply an atom that as lost electrons through this process, therefore there is a positive charge because there are more protons.
A negative ion has gained electrons, having a negative charge because there are more electrons.
I have attached for the last time to show the existence of the Ruslan nanosecond generator (As reverse engineered like i did from Akula circuit diagram)which was not mentioned by him via circuit diagram.
magpwr
To Enjoykin and MenofFather,
Greetings comrades.
I need one of you help me to sent my  "Reverse engineered" and working nanosecond pulse generator circuit to the Russian forum.
Let them have the nanosecond generator circuit.They may not be aware that this circuit is currently used by me and itsu maybe.
The circuit i attached is ok to copy up to the IGBT driver stage only without the mosfet or transformer which is only good in stimulation.
I have attached version 6.2 and version 7.0 which also my latest working nanosecond generator for you to communicate with fellow Russians in the forum.Please put it in that forum.Thanks in Advance.
Please rename this attached file in Russian.
Power supply at transformer instead of 12volts it suppose to be 150volts to 170volts.
TC4422 suppose to be TC4420. :)
Version 7.0 RV2 instead of 5Kohms pot it suppose to be 2kohms.
That's all.
NickZ
   Well guys, looks like I'm out of game for a while, sitting on the bench, as my last two IRFP260N fets have gone up in smoke.  I'll need to obtain another batch of them, to continue.
   Before these fet's final good bye, I was lighting  3 110v, 100w bulbs nice and bright, which would light my house pretty nicely. But, only for a few seconds, before they would become melt-down hot.  Anyways, I'll have to order some more of them, ASAP, and then wait a month for them to come.
I don't know my fets always get so hot, as they are rated at 200v, 50 amps, and I'm not drawing anywhere close to their maximum ratings.
  I notice that there are different brands of these same fets, and some brands may work better than others. Some brands only cost a buck a piece, for 10, or more. But, which brand are being used by Ruslan, would be my question. As even when they are new, there have some differences between them, and therefore don't all work the same.
  Guys, remember that both the grenade coils (bigger and smaller 12,12, turn coils), are connected together, tuned by the 0.47uf caps, and also connected to earth ground.
  No one is using 25,25 turns coil for the air coils input coil, only 12,12 turns. The diagram that states that this coil is 25,25 does not correspond to what is being used by Akula, or Ruslan. Please keep this in mind.
  The tuning caps are most important... but, possibly are not the same ones that will work best for your circuit. I've tried on many different tuning caps to see which ones work best. 0.22uf, 0.33uf, 0.47uf, 600v to 2000v, etz... in parallel, as well as in series. That is how I was able to light up to 7 100w bulbs. Also my feed back circuit, using the flyback core, the rectifier diodes, and caps, going back to the input side, added much more brightness to the device's output.
  So, here I sit, on the bench now... fet-less, just watching what you guys are up to.  Hoping to get back in the game, soon.
