0 Members and 135 Guests are viewing this topic.
Void
I have to wonder at all the people who keep posting comments here saying you
must do this and you must do that, and you must wind exactly this way, and you
must use this exact frequency, and you must use these exact wire lengths, but none of those
people have a self running device to show. ;D  It is one thing to pass along specific things that
Ruslan and Akula have said (both who seem to have self running devices), but all this other
stuff getting posted here as absolute must do facts is in reality just speculation. :)
Untill you have a self running device (with no tricks of course ;)) it is of course all just speculation.
Nothing more. Even Ruslan seems to be struggling and having to spend many hours trying
to get a good higher power and stable working version of Akula's  second self runner. Ruslan appears
to be trying to replicate Akula's device as closely as he can (he is doing a great job of that) so he can
see if he can get more available output power capacity. If Ruslan doesn't understand all the ins and outs
of how these devices work (beyond the generality of pulling in energy from the ambient), then for sure
it is not so straight forward, and there is a lot to be figured out yet. Be wary of those who are
telling you exactly how everything should be done, but who have no self running circuit to demonstrate.
In reality they probably know about as much about what exactly it will take to make this device work as your
mother knows. ;)
Keep smiling and all the best...
Enjoykin
Forums are for sharing useful informations not speculations. I use principle from slogan"Take It or Leave It".
Problem is in this: Nobody on this planet knows how to correctly extract free energy from ambient and does not know about hidden physical process involved. This worth starting from Official Nobel prize winners to simple people which make experiments in attempt to get some results. Understanding of principles is most important - but how can you thought about tyny processes without informations collected from own and other people experiments ??
Those people which have self running device - for sure not sit of forums and flood and spam.
Void
If you are looking for a simple way to temporarily support your coil assembly
while you are doing your testing, you should be able to find parts similar to  this
at hardware stores. There should be various different parts options along these lines.
This is what I am going to use temporarily to support my coil assembly. I haven't cut down
my pipe length yet, so the coil assembly will actually be shorter once it is cut to length.
Seems like a simple way to support the coil assembly without having to mess around too much.
I wonder how the black pipe compares to the white pipe. I have heard that the white pipe may
be better for this type of application, but I am not sure if it really makes much difference. One
may possibly be more lossy than the other for use as coil formers.
All the best...
Void
Quote from: Enjoykin on October 19, 2014, 09:47:14 PM
Problem is in this: Nobody on this planet knows how to correctly extract free energy from ambient and does not know about hidden physical process involved. This worth starting from Official Nobel prize winners to simple people which make experiments in attempt to get some results. Understanding of principles is most important - but how can you thought about tyny processes withou informations collected from own and other people experiments ??
Hi Enjoykin. I wasn't commenting on people sharing their ideas and experience. Sharing ideas and experience
is a good thing. It is the comments where people are saying you must do this and you must do that rather
than they have an idea that this might possibly be better, or maybe things are possibly working like this or maybe like that.
A big difference. It's all about how it is presented. For myself anyway, until I see a working device from someone
I will definitely take anything being stated as an absolute as just some ideas which may be true or maybe partially true,
or which may actually be quite false. I know for myself that every time I think that I am starting to understand
how at least part of this device might work, I do further experiments and then I am not so sure again.  ;D
All the best...
Enjoykin
Схема Topruslan 6  :)
Установка Руслана Кулабухова
http://www.youtube.com/channel/UC_zn0cdzv_qfsxQUm4e7R9w/videos
Успехов !!!!
_________________
Brovin's Katcher info
Magnet wire 0.8mm diameter on 50 mm tube diammeter about 11,5cm....12cm lenght on same axis as Grenade coil. Secondary direction opposite Katcher primary.
All power now going from 24V/7A - use two accumulators 12V/7Ah each.
All 3 fans are for 24V
End of Grenade (coil 6 is now grounded). All grounding in one point and with conductor 16 mm2 at copper bar in earth.
If you use computer PS use power isolation diode for min 7A on output of PS.
