0 Members and 150 Guests are viewing this topic.
d3x0r
Oh well... lost some.
I concur posts that say "MUST" and "MUST NOT" are discouraging.  May, Can... are better negotiating terms.
Kacher tuning; the primary definately matters... between 2 and 8 turns is quite a difference of avaialble wave forms.  Also have my primary kind of close to the secondary.
Need to document some of these changes as I go through them... even with a filter choke and caps the signal still leaks to the power supply side... although I do have something that may be inducting a pickup kind of near.
I have a low frequency (485Khz, 856Khz kinda) resonanting going on; I changed transistors also.  I added dual 5V zeners , and tried an additional diode from the base to ground, but the base refused to stop going below ground.  But at different voltages I can see ringing that's high frequency; even up to 10Mhz.... I guess that's on the collector from the secondary.... well I guess it's somewhat isolated from 'ground' so relatively it's really not below ground....
Is there advantage to driving the coil as kinda a dipole - as in from the center with power on one side and the other open?  So many things to make note of...
was trying balancing resistors to power and ground to the base too... and was able to tune the same coil up to 1.12Mhz something... but it was really noisy, and needed to be a better harmonic.  So ...
49m = 6.122448979591837Mhz
I can get 2.5Mhz with 2n3055 that's no good
could wish the kacher didn't have to have amps... it does doesn't it?
*shrug* kacher is pretty weak stiil
Hoppy
Quote from: Enjoykin on October 19, 2014, 10:17:16 PM
Схема Topruslan 6  :)
Установка Руслана Кулабухова
http://www.youtube.com/channel/UC_zn0cdzv_qfsxQUm4e7R9w/videos
Успехов !!!!
_________________
Brovin's Katcher info
Magnet wire 0.8mm diameter on 50 mm tube diammeter about 11,5cm....12cm lenght on same axis as Grenade coil. Secondary direction opposite Katcher primary.
All power now going from 24V/7A - use two accumulators 12V/7Ah each.
All 3 fans are for 24V
End of Grenade (coil 6 is now grounded). All grounding in one point and with conductor 16 mm2 at copper bar in earth.
If you use computer PS use power isolation diode for min 7A on output of PS.
Enjoykin,
Thanks for this info  and reply on earth cable. A couple of comments: -
Its interesting that the Kacher secondary winding is now quite short at around 11.5cm...12cm and confirms what Itsu has found in his latest video. I'm wondering if as I mentioned some time back, whether Ruslan used that strip we saw in his video to insulate and spread groups of windings, giving the impression that the coil is much longer. This matter needs clarification.
The circuit diagram shows 24V 3-pin voltage regulators being input 24V and output 24V. This is strange given that these regulators cannot output a properly regulated voltage at the same voltage as the input. More importantly, the TC4420 mosfet driver has a supply voltage rating of 20V max! Did Ruslan produce this circuit diagram?
itsu
Quote from: AlienGrey on October 19, 2014, 05:54:11 PM
Itsu, i have no idea where  you have the 15 volt zeners, but can you next time put 2 3.7volt basic to back zeners or so in the base of the bipolar switcher to zero, or protect it, or if you will exceed the base emitter voltage you will blow the device into the next life, you could look up the data of your device on the net. All the best, keep up the the good work ;).
Thanks AG,
I have requested the schematic of this VSP 2410 Voltcraft PS, but it seems its not available with them (Voltcraft/Conrad) >:(
There where 2 15V zeners protecting the gates (not enough it seems) which i have ordered and will be replacing one on one.
Regards Itsu
itsu
Quote from: magpwr on October 19, 2014, 06:18:09 PM
hi itsu,
Have you factored in the 60th Subharmonics of 2.1MhZ which now your circuit need to run at 35khz just be in sync.
If you do a scope ref save base on your current setup at 2.1Mhz and if you are still sticking with 26.1khz.You will definitely noticed that both your waveform will not be aligned at all.
Maybe simple solution for you now is to slowly increase the yoke driver frequency to 35khz and observe if there is any increase in brightness without the nanopulse generator.
I have attached the harmonics calculator once more with your 2.1Mhz in it and please take a look at 60th Subharmonics as rough guide.
You do have the gift in producing elegant setup with the proper tools and  a nice bench but it would be pointless if you don't strictly follow the rules of harmonics as a guideline."Please don't be offended"
Ruslan did mention somewhere in forum do not use the spectrum analyzer for the multilayer coil.
At 60th Subharmonics if you got my point.
"Dear all this is not a science fair project provided if you realized this by now.I even noticed some of you don't even care about the spacing for the outer layer and simply wind this directly thick wire onto the coil.The reason for the spacing is to ensure the tesla coil resonance will not be tampered with if there is load eg:bulb.Provided if you are still serious in creating this device.This project is not about who finish first it's far more than that"
Thanks Magpwr,
i mentioned above that i was tuning the thing so i did change the TL494 frequency up and down, but no special effects seen other then that the bulbs went out   :P
As my 2x 25 coil with the 0.47uF cap resonates at 26.5 KHz, setting the TL494 to 35KHz kills the resonance, so i have to adjust also the capacitor to match.   Quick check shows i need about 0.22uF, so can use 2 of those 0.47uF caps in series.
Thanks, Regards itsu
Enjoykin
Thanks Hoppy
All mistakes fixed - for present time !! :)
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg420547/#msg420547
Hoppy quick calc give me these values:
total lenght of Ruslan Katcher secondary wire is 24 m for 12 cm or 23 m for 11,5 cm Katcher secondary lenght. Wire lenght from end to end.
If you have some online calc you can estimate roughly inductance.
If we take in account about 2x 25cm for both ends it will be with 97% probability from 23,5 to 24,5 m, Retuning should be with attached ground.  :)
What is interesting to me is total lenght of Katcher secondary is 6,25 part of Kathcer wave lenght which is 150m. Of course this lengjht need to be retunned again for first start. Finest tunning should be done with small bifilar choke with two opposite windings at distance 3-4 cm.
Reg..
________________________________
Man called Denny from our Russian forum has caught OU effect - but only 60W power for free. What is interesting is he was excited not bifilar inductor but Grenade coils layers 5 and 6.
Now he rewounded coils so will see does he wiil catch OU effect again or not !!
his video
http://www.youtube.com/watch?v=hlLLiwzfoeE
Hi Itsu
Try to lower resonant frequency of your Grenade on 17,5KHz...18,5 KHz. For this you will need capacity about 1uf-1.2 uf. Two 0,47uf capacitors and one or two from 100nf.
What i want to say is this:
Katcher must resonate on some odd harmonic of resonant frequency of Grenade coil. Grenade is our reference point.  We need wave resonance here. Wave resonance is centering many small wavelanghts to one biger. or simple we need to devide one wave lenght on odd equal integers.
Only in odd integers we have constant phase shift for both wavelenght,
Try analyse picture - настройка:
I was watching Akula video and saw he was tunned his Tesla transformer on 3rd overtone of Grenade resonant frequency.  It was about 170KHz.
Number of harmonics for Katcher must be odd because we must put whole number of Katcher periodes to reference periode of Grenade coil. (worth also for wavelenghts).
I want to ask you to record in high resolution complete cpectra from 0 Hz up to 100 MHZ on your Tektroniks oscilloscope and to zoom main spectra peaks especially in lowest range from 0Hz up to several MHz. I need these data to try catch some correlations between processes here. I think there are involved several very complex processes. You can use 1 m copper wire at couple of meters distance as antenna for your 50 ohm analyser input.
Reg.
Let's teach from Master of Electricity - Great Nikola Tesla about phasing coils.
Analyse picture below.
Reg.
