0 Members and 150 Guests are viewing this topic.
Void
Quote from: Hoppy on October 20, 2014, 07:40:15 AM
Hi Void,
Yes, I do catch your drift and although I am taking this project seriously because IMO it flies in the face of credibility. Ruslan appears to have worked through numerous variations and we just don't know how many, if any of these have actually self ran. Its just a case of assuming he did succeed as he does seem to spend a lot of time sharing build information and is presumably sincere. Alternatively, he just likes keeping people up to date with his experimentation towards the goal to achieve a self-runner.
Hi Hoppy. It appears Ruslan had at least a couple of circuit variations self running.
One with a nanopulser driver (transistor kept blowing on him I believe) and another variation
with a kacher driver of some sort. I can't say for sure if it was real of course, but Ruslan does seem
sincere and he is putting a lot of effort into these devices, just as Akula did.  I am inclined to think it
may well have been working as shown anyway. I just think that Ruslan is still trying to figure out many
things himself, and therefore is doing a lot of experimenting and trying different variations like the rest of us.
The difference is that if he did have those previous circuits self running as shown, he probably has a much better
idea of what direction to go. :)
All the best...
Jeg
Guys so many things to tell so I will keep it at the basics.
Itsu, it was my false that I never told you my initial katcher setup while I noticed the drifting. I was using only the two bias resistors at the gate and nothing else. The most simple arrangement. I wonder if you have something else connected to base and so keep your frequency steady! Please advice.
Void, I am very sorry but my eyes started to deceive me. Just today I searched and found your katcher answer. :)
Enjoikin. Mission complete. Everything is aligned now in terms of resonance and I already ordered the beers!!! But let me describe what I did in case that somebody else is on the same spirit.
My design is the one of Ruslan's hand made.
Grenade and 28T are in series. Both lengths has to be measured and calculated. My grenade on a 5cm pipe has a total of 32.2m. 28T winded on my yoke are 4m. Connection wires length total 1.7m. All together comes to a 37.9m. I omit some 40cm from the connection wires and vouala. My line now is 37.5m and it is the first time that my base frequency correspond to the right and calculated wavelength.
Then, I measured the line of the 3T circuitry. All the line from capacitor's leg to leg was 12m. Including the inductor the 3T length and the length of the connection cables. I added in series a heavy wire choke of 6.75m.
Total 18.75m
I rebuild my ground so now I also have a 18.75m cable up to the copper rod.
My latest measurements are at last aligned to the calculated values. 8Mhz base frequency, 2Mhz and 1Mhz dominant sub-frequencies, with 1Mhz giving the higher peak. Both of the lines now give rise synchronously at the same frequencies and harmonics. I feel guys that this was one of the last Ruslan's secret keys. Now it is a matter of time and team work to drive it to the end.
Ps. Enjoikin my friend all of the people inside here are somewhat dreamers. The ones that are not are on the www.underunity.com :D
Enjoykin
Thanks for reply Itsu !!  :)
Yes, you are right I mean on 2x 25 turns bifilar coil. He was wounded on Grenade so i see him as Grenade coil.  :)
Ruslan has not drawn any schematic except that block diagram so we can conclude about his device in details.
End of Grenade is 6th layer from my point of view. Ruslan has mentioned in his 108 min interview that end of Grenade should be grounded. Also Dennys told me the same because he catch effect but very unstable. I suspect on synchronization because he did not made PLL circuit and control logic. He was excited end of grande where are all 6 layers and got effect while on bifllar side nothing. He was planed to rewind complete Grande coil exactly like Ruslan grenade. What is interesting Ruslan did the same. His brown coil is not the same as last one shown in his newest video. Brownl coil was complete mirrored in respect to 2nd - new coil. You can try both version 6th on ground 1st on yoke like in my schematic or 6th on joke 1st on ground. Try if you want.
Keep in mind on Blue coil as i have shown in my recent posts. Picture was recorded from working 5kWatt device. Winding directions are exactly same like Ruslan Grenade.
That schematic i was drawn for myself and it is not complete schematic. Maybe Ruslan will draw complete working schematic but maybe.
About scpetra if you want you can scan 2x 25turn bifilar coil. No need to 100MHz - only to 10MHz.
I was thinking you have wide band spectrum analyser in your equipments. I was wrong.
The reason why i have asked you to record spectra is to find all harmonics involved and find some correlation between them.  I think main role here are plying odd harmonics of referent frequency 17KHz---35KHz.
Have you any idea why Akula tunned his Tesla exactly on 3td overtone of referent frequency?
Why not 2nd or 4th ??
Little time ago i was drawn simple snubber schematic for IRFP260N fets from Akula picture.
Maybe help somebody,
On above picture i was swapped markings for bifilar and Tesla coil in equation.
Shoud be fTesla = k x fbif:)
It mens resonant frequency of Tesla (or Katcher) coil is odd multiple of resonant frequency of 2x 25 turns bifilar. Take attention how 3 full periodes completely merge in one big periode 3 times longer,
On even harmonics you never be able to do that.
Enjoykin4
Void
Quote from: itsu on October 20, 2014, 07:54:30 AM
Also there you see that the link drawn in between the Grenade coil and the 2x25 t coil is missing in this latest diagram (it was never in the older
ones either).
So more confusion here.
Concerning your request about "to record in high resolution complete cpectra", no problem to help if possible, but i am not sure i follow you.
My Tektroniks oscilloscope is just that, an oscilloscope, no spectrum analyser, or do you mean the FFT function?
I then need to sweep the whole range  0 Hz up to 100 MHZ  using my Function generator.
And what to scan?  The grenade coil, the 2x 25turn bifilar coil?  Please explain.
Regards Itsu
Hi Itsu. It has not really been translated what Ruslan said when he drew that connection between
the two yoke secondary windings. It would help if a Russian speaker could translate what he said there.
I wasn't clear at all if Ruslan was just showing that you can ground one side of both windings, or if he was
saying that a possible variation is you could do away with the series resonance winding and 2x25 winding
part and just drive the grenade winding directly with one secondary winding on the yoke. Maybe he was
just pointing out that you can ground one side of both windings however. Not sure at all.
The following might work. If your function generator has a setting that produces a good broad frequency white noise signal
well into the high MHz range, you could drive your grenade coil with that and monitor with the FFT spectrum analyzer mode
on your scope. You should see some peaks at frequencies where there are resonances. Although
Akula made a video talking about locating such resonances, Ruslan seems to put little importance
to them. Ruslan says he is basing everything thing off fractions or multiples of wire length.
Seems to be working for Ruslan. :)
All the best...
Void
Quote from: Jeg on October 20, 2014, 08:20:15 AM
Total 18.75m
Hi Jeg. No worries mate. Just wanted to make sure you saw that comment.
Interesting that you are getting a resonance right on 2MHz and 1 MHz with
your new coil setup. That 6.75m choke in the series resonant loop will
likely lower the voltage at least somewhat across the 2x25 (or whatever winding count you used)
primary winding on the grenade. That is because it will drop voltage across it and take
voltage away from the primary winding. It will also likely reduce the current in that loop
a fair bit as well.
All the best...
