0 Members and 53 Guests are viewing this topic.
Jeg
Quote from: Void on October 20, 2014, 08:50:31 AM
Hi Jeg. No worries mate. Just wanted to make sure you saw that comment.
Interesting that you are getting a resonance right on 2MHz and 1 MHz with
your new coil setup. That 6.75m choke in the series resonant loop will
likely lower the voltage at least somewhat across the 2x25 (or whatever winding count you used)
primary winding on the grenade. That is because it will drop voltage across it and take
voltage away from the primary winding. It will also likely reduce the current in that loop
a fair bit as well.
All the best...
That is the why I wind it as a current choke. Two wires same direction bifilar winds connected at the top.
Very low inductance so doesn't affect much the output voltage..
In addition because of the fact that cancels out its own magnetic fields, reactive voltage from coil is minimum so doesn't affect the passing of current.
First image the choke
Second, the signal thief from 3T circuit for katcher sync
Ps. My 25+25 is winded as 12+12 at the thin grenade side, and 12+12 opposite direction on the thick portion of the grenade. This is for loading the grenade more properly as it has the same pole on both outer sides, and same poles at the middle of the grenade squeezing one the other.
Void
Quote from: Jeg on October 20, 2014, 08:59:02 AM
Hi Jeg. Ok, I see how you did that choke now. That was a clever idea for lengthening that wire.
You have some really innovative ideas in there. Let us know how the testing goes.
All the best...
Jeg
Quote from: Void on October 20, 2014, 09:24:51 AM
All the best...
Thanks Void, I wish you the same :)
itsu
Quote from: Jeg on October 20, 2014, 08:20:15 AM
Guys so many things to tell so I will keep it at the basics.
Itsu, it was my false that I never told you my initial katcher setup while I noticed the drifting. I was using only the two bias resistors at the gate and nothing else. The most simple arrangement. I wonder if you have something else connected to base and so keep your frequency steady! Please advice.
Sounds great Jeg, good progres.
Concerning my Kacher, its even more simple, just the 2SC5200 transistor and a 2.2KOhm resistor, see diagram.
Mind you, there it shows a PNP transistor, my 2sc5200 is a NPN, so change the plus/minus.
In front of the 1:1 transformer i have a variac connected to mains so i can vary the DC from 0 to max. 400V DC
Regards Itsu
itsu
Quote from: Enjoykin on October 20, 2014, 08:27:50 AM
Thanks for reply Itsu !!  :)
Yes, you are right I mean on 2x 25 turns bifilar coil. He was wounded on Grenade so i see him as Grenade coil.  :)
Have you any idea why Akula tunned his Tesla exactly on 3td overtone of referent frequency?
Why not 2nd or 4th ??
Enjoykin4
I understand that on symetrical AC signal there are no even harmonics.
Try Googling "odd harmonics, or perhaps someone else could confirm and/or explain better why."
Regards Itsu
