0 Members and 232 Guests are viewing this topic.
Hoppy
Quote from: T-1000 on October 21, 2014, 08:37:51 AM
Please see http://en.wikipedia.org/wiki/Oxygen-free_copper for last  question.
Also the Tesla coil wire length is quite short for 1/3rd of full wavelength of grenade coil (its wire length multiplied by 4 for full wavelength)...
To avoid any misunderstanding of your statement above, please give Tesla coil secondary length based on a grenade coil wire length of 37.5m.
NickZ
  37.5 meters divided by 4 is 9.375 meters, as some of you may already know.
  So then, how many turns would that be if wound on the pvc drain tube used by Ruslan, (which is NOT 5cm, but is about 1 1/8 inches in diameter). If wound with 20-22 gauge magnet wire?
   The blue TK coil is wound on even smaller diameter pipe, which looks like about 3/4 to 1 inch, or so.
  Too bad we are still guessing at all of these important details...
   It may also be that the grenade coil may not really need to have the coil cancelling effect, to work as it should. This would need to be tested against the one single wire coil 37.5m long, not opposite wound.
T-1000
Quote from: Hoppy on October 21, 2014, 10:22:42 AM
Ok, here are example calculations. I might made some mistakes based on understanding and will adjust it in an process if needed:
The base pipe diameter is 50mm and the length is  20 cm
Calclutated wire lengths (2piR*length / wire diameter (skipped at the moment)) according to http://www.1728.org/freqwave.htm
31415.926535897932384626433832795 mm - layer 1+2
15707.963267948966192313216916398 mm - layer 3+4
7853.9816339744830961566084581988 mm - layer 5+6
1/4 wave 54977.871437821381673096259207392 mm -  5.453MHz - main grenade coil
full wave 219911.48575128552669238503682957 mm -  1.3632MHz
1/3 wave =  73303.828583761842230795012276522 mm - 4.0897MHz - tesla coil 1/4
Tesla full wave 293215.31433504736892318004910609 mm =  1.0224MHz
Inductor 1/2 wave = 109955.74287564276334619251841479 mm 2.7265MHz
Inductor 100th harmonics = 10995574.287564276334619251841479 mm  27.265kHz
P.S> Ruslan used wire of 2.5mm^2 (diameter 0.8mm) so you can practice and adjust this :)   Also we have 2 layers not 1, so you need multiply length by 2
Cheers!
Void
Hi T-1000. Did Ruslan say what wire length he is using for his secondary winding on his tesla coil?
All the best...
T-1000
Quote from: Void on October 21, 2014, 11:29:57 AM
All the best...
Nope, he just was talking only about tube diameter, width, wavelength and frequency.
