0 Members and 340 Guests are viewing this topic.
Enjoykin
Hi Itsu.  :)
Watch Akula videos
http://www.youtube.com/watch?v=fp3sed_eli0
http://www.youtube.com/watch?v=PLs7v6t3QMY
I think both vids were translated !!
Itsu if you did not rewounded your old Grenade coil, save spectra withouth grounding - for yourself. Read all maximum peaks from 0 to 10MHz and compare them with your already given peaks (grounded coil). Then you will see how the "Earth influent" resonant effect. The goal is to catch "Earth response" and find only one earth frequency like Akula did and Ruslan did. Once you catch that frequency (depend of lenght of coil and depend from gound conductor) you can easy make kacher working just on that frequency. It mean you will have support point.
Your oscilloscope and signal generator should be grounded on fully separate ground. (for example Ground 2).
One more thing. You has "kicked@ your LF sinusoide with Katcher impulse amplitue about 1KV. And nothing has happened. Akula has kicked sinusoide with very sharp HV impulse amlitude more than 36 000 Volts. He has burned his HV probe because amplitude have been much higher than 36 000 Voltas.
Maybe more than 50 000 Volts. This is very important tip because proces or processes here have threshold level more than 36 000 volts. Much more. It is only one of many tricks involved in OU effect.
Last tip from Akula today - Earth frequency response (your grounding response) with quality grounding - will be around 2MHz and below 2MHz but higher than 1.5MHz. It will be some Harmonic of Maximum Earth Resonant frequency peaks between 4MHz....7MHz nut not so high in amplitued. Also valid LF resonant frequency must be harmonic of those higher resonant peaks which again should need be used as Kacher support point (or Tesla Transformer support point).  As Akula said it is extremely difficult thing - tuning complete circuit on higher frequences with several simultaneously working interconnected processes. If you failed to find that Earth resonant support point you will not be able to make working generator as Akula said.
Reg.
Best wishes !!
Void
Quote from: itsu on October 21, 2014, 04:47:51 PM
The diodes and choke in the green box makes the now dc voltage across the bulb go negative compared to ground,  right?
At least it does with me, so ground becomes the more (60V dc in my case) positive side.
Hi Itsu. Ruslan showed it that way on his schematic, but I don't know
that it has to be that way. Ruslan also said and showed on his schematic that you
could use a FWBR as well, and in that case it wouldn't matter. Ruslan showed four rectifier diodes
when he opened up the box. Akula showed no diodes at all in his schematic.
All the best...
magpwr
Quote from: Void on October 22, 2014, 05:33:09 AM
All the best...
hi void,
The 4 diodes is form as full-bridge rectifier is to charge the pulse capacitors connected in parallel at 170volts for that device.
Guys most of you will face issue between tesla coil and yoke driver frequency because this 2 frequency is not aligned.
New discovery for me i just found out for Akula he is using 30th Harmonics instead of 60th Harmonics.I just took 55.03khz as per video and applied into harmonics calculator and take a note at 30th Harmonics it will show as 165khz.(No spectrum analyzer needed for this) ;D
Good thing my earlier posted circuit can be switched to div by 30 instead of 60 easily.
It seems Akula was using 30th harmonics and Ruslan was using 60th harmonics.Both frequency are also able to be aligned.
The coil which Akula was using as per video is for the older design.Base on this older video Akula Yoke needs to be driven at "55khz" for 30th Harmonics.This will put more strain on components eg:IGBT.
Akula video #5  translated by Wesley. ( Free Energy device)
http://www.youtube.com/watch?v=PPHipGkfSAY&list=UU1ZrGlkxBvG9WOwIs2eApLA
itsu
All the best...
Hi Void,
i think those 4 diodes on his diagram (also visible in my picture with the green box) is not a FWBR configuration, but just
4 diodes in a series /parallel config to distribute the voltage/current.
Anyway, i agree, no such diodes in earlier Ruslan/Akula diagrams   :o
Regards Itsu
Void
Quote from: magpwr on October 21, 2014, 10:49:52 PM
hi guys,
I have just completed designing my Tesla coil to Yoke driver stage with duty cycle control which will be perfectly in sync with the Tesla coil at 1/60 the frequency of Tesla coil.
Hi magpwr. Interesting idea. It may be that the frequency relationships are not really so
fixed however. Based on my own experiments so far I think it may possibly not be so fixed,
but I can't say for certain at this point. What you are suggesting might work however if the frequency
relationship can always remain fixed to a specific ratio. :)
All the best...
