0 Members and 101 Guests are viewing this topic.
magpwr
Quote from: Void on October 22, 2014, 05:57:47 AM
Hi magpwr. Interesting idea. It may be that the frequency relationships are not really so
fixed however. Based on my own experiments so far I think it may possibly not be so fixed,
but I can't say for certain at this point. What you are suggesting might work however if the frequency
relationship can always remain fixed to a specific ratio. :)
All the best...
hi Void,
After the recent discovery of 30th and 60th Harmonics used in device.
I came to a simple and straight forward conclusion at-
30th Harmonics-Yoke driven 55khz (Akula video translated by Wesly as attached earlier)
60th Harmonics-Yoke driven from 18khz....37khz.(Current device of Akula and Ruslan)
All these figures are within the specs of the yoke ferrite material capability.If you think any higher frequency possible yes but yoke core is not capable since we know it's designed to work till around 75khz.
Or any lower than 18khz the "Air-Core" multil-layer coil as a whole don't perform well.
In simple words what i am trying only 30th or 60th Harmonics is valid and the best choice to get both frequency aligned
.At 15th harmonics the frequency is way below air-core capability(Way below 18khz) at 120th harmonics it exceed the yoke core material capability since the frequencyto drive yoke core would exceed 70khz and easily goes into 100++khz .At this point yoke fails due to core saturation although air-core work work better at higher frequency.
There is nothing to worry as long you stick with the harmonics calculator 60th Harmonics typically or 30th Harmonics.
It's "fool" proof. :)
After alignment there is still nanosecond pulse to be injected.If anyone recall "the knife" as mentioned by Nicola which to me is the nanosecond waveform which looks like a knife blade facing upwards.
But if my unconfirmed theory is correct once these frequencies is aligned at 60th Harmonics then maybe current consumption should drop in order to light the bulb with same low brightness,without nanosecond pulse injected yet.
Enjoykin
Hi Jeg   :D
Excellent job my friend you have done and very clever.  :)
Keep your Over Unity work up !!
Reg,
enjoykin !!
Enjoykin
Quote from: skywalker66 on October 21, 2014, 02:40:46 AM
Hello ! That is most interesting my friend. I wish to know more about this experiment. Can you please provide more info about this setup ? or a source of it? It seems to be a well done tuning between kacher and grenade coil which is the very first step in replicating Ruslan's device.
Hi skywalker66.
You already know a lot about. It was experiment with Ruslan' s device with strange wounded coils. Effect was very unstable beacuse some parameteres were not valid. Yes tuning is important but you shoud need several valid arrangements to continue. It is not only like winding coils, making oscillator, katcher, connect light bulbs and expect something will happend in tuning. There rule serious systematic approach and sharp analysis of mistake - no Tsar way here. This is my point of view.
Reg.
Enjoykin
Hi d3x0r  :)
I can't comment because i don't know your setup. I need a more inormations.
In Ruslan's device there did not preseted any NE555 or exotic components.
Do you have some spectrograms of your "Earth response"?.  I suppose you already have good independent Earthing (grounding). Don't use common house grounding because there exist a lot of noise which can affect your generator and will be extremelly difficult estimate what is going in generator, how and from what !! Take atention Akula doing all his experiment on calm place in his personal dacha long away from his house in town.
Try to find translated above listed videos which i gave Itsu to watch. In my oppinion they are most important videos Akula ever has been recorded - till now.
Reg.
d3x0r
Quote from: Enjoykin on October 22, 2014, 06:54:50 AM
Hi d3x0r  :)
Reg.
555 isn't 'exotic' as it seems... it's just a pulse width modulator thing... only it's only one half instead of tl494 symmetric dual output... but... it's the same...
most of it wasn't specifically to you, just noting you said...
No I don't have fancy equipment... my signal generator is manual.
https://www.youtube.com/watch?v=5mJ69PlY7HA
link back to text in description... and a rough sketch, it's just the 25x25 coil and the grenade coil (simplified in sketch) output being grenade.
found lots of resonances, some so I had power on the ground side.
I have a ... 12m ground wire, that's seperate enough such that I can measure the ground all the way to the plug and see a signal from the coil, but cannot see it on the other side of the ground from the same wall.... I don't have 'ground' there's no moisture.
