0 Members and 120 Guests are viewing this topic.
MenofFather
I try found ground frenquencies so caled. And found that my short wire coils resonate all almost on same frenquency, on about 900 kiloherc (if coil frenquency without ground about 2-4 megaherc). If coil frenquency without ground is 600 kiloherc. then addading ground, coil resonate on about 100 kiloherc. So if coil frenquency quit hight (2-4) megaherc, then addading ground resonance gose down to same about frenquency: 900 kiloherc. But if you made from coil 2-4 megaherc kacher or tesla coil, then it not resonate on 900 kiloherc with ground, it resonate on 2-4 kiloherc, and that coil who resonate on 100 kiloherc testing with akula metod, if made from it tsla coil, then it resonate on about 600 kiloherc, I remeber...
MenofFather
My test schematic. Osccilioscope were line is punctir can be conected to ground, then signal on oscilioscope much better, but resonant frenquencies not change on that.
itsu
Quote from: MenofFather on October 23, 2014, 03:35:32 AM
Thanks MenofFather,
but did you use the method described by Akula to measure the resonance frequency peaks of your coil??
It does not work with me.
When using my normal methode to measure the resonance of a coil (2 turn wrap around the coil to be measured and connecting
my FG to it and probing the coil with my scope) i DO see some sharp resonance peaks, also around 900KHz and 2 and 3MHz.
Grounding the end of the coil will change these peaks frequencies, but when using another coil, again i have different frequencies.
So not a specific "ground resonance frequency" (like 1.8MHz) to be found on MY ground.
Regards Itsu
Enjoykin
Itsu Akula has in his dacha laboratory 3 grounds.
One for instruments oscilloscopes. spectral analysers etc. other independent for tunning his generators and third for home devices.
Dont use same ground for oscilloscope, signal generator and your generator because return currents and noise. If you have flast response  - something is wrong with ground. In any case you need make new two grounds.
Reg.
Hoppy
As we see from Kapanadze and Akula videos, the ground wires are long and length of wire may be a critical factor in achieving tuning to a specific Telluric frequency. Having separate equipment ground makes sense as Enjoykin points out. Maybe incremental adjustment of ground wire length to a given coil setup may prove more helpful in establishing a specific 'sweet spot' that can be identified as a responsive earth frequency. However, it is becoming clear that we need specific guidance on tuning to the ground and preferably well translated into English!
