0 Members and 346 Guests are viewing this topic.
Void
Quote from: MenofFather on October 24, 2014, 02:36:17 AM
Bifilar frenquency is 32 kiloherc. Kacher frenquency is 1,6 megaherc. Power supply is 24 V 6,5 A. Lamps is 4 x 500 W.
Diodes is burning often.
Quote from: MenofFather on October 24, 2014, 03:53:23 AM
Kacher secondary wound in last video 0.8-0.81 diameter wire 9 cm lengh on 5 cm diameter tube. And then to oposite direction with ticker wire little .
Thanks MenofFather!
skywalker66
I found that quite interesting:
Svyatolug writes:
"The role played by the choke chain Kacher antenna, and what happens when domotke-unwinding turns on it?" He adjusts the frequency. It is not needed, it is possible without Ferit, but simply on a reel to reel plasmasovy frame 1 meter of wire in the rubber insulation. It is a self Shark confused and confusing others with these impulses and fronts, in my opinion, because without these Ruslan droseley quietly launched and Shark unaware that these droseley figured out how not izvechtno this drosel, almost no any magic and almost most important, almost the heart of the installation. Fact suggests the opposite. Therefore, with this droselem time to finish. Just some say, because they just want to make it. I do wonder how such nonsense Shark carries with it throttle and in his other expressions, like smart setup with samozapitom create one, and sometimes bear such nonsense (if this would be a key drosel some, it would Ruslan installation without would not work, and he has repeatedly shown that without working for self recording). :)
In the installation Ruslan resonates not removable 1.5-1.7 MHz, and an inductor. I checked, and it seems to pravdu.Poetomu he irradiates over the inductor. Indukrtor has a resonance at 17 kHz, plus then dobavlyaetsya resonance coil without a capacitor to ground at 1.5-1.7 kHz and these ddva resonance smeshivayutsya and from the land poluchaetsya current. That's the conclusion I came to me and while it looks like a likely the most. Because if no inductor chase the frequencies detachable coil there are no resonances near 1.5-2.1 MHz. And if you get rid of one inductor to frequencies, you should find a resonance within the 1.5-2.3 MHz. But the inductor must be 11 meters, as in the installation of Ruslan, not as he advises everyone to do from 18.7 meters.
In some of the videos from Ruslan we learn that he works for or is closely associated with a commercial broadcast radio station. We have even seen inside the station at one point.
Does anyone know the transmitter frequency of Ruslan's commercial radio station?
magpwr
Quote from: Acca on October 24, 2014, 06:09:25 AM
I have just seen the last 3 video clips from Ruslan and they are really good.. Just have been acquiring materials and test equipment to make the Ruslan device, thanks for all the great comments mag's, and to the new member Enjoykin.Itsu the most advance in this replication.. Even the Russians are envious of you !!
Off topic somewhat, ELECTRIC WATER..
Here is a clip of mine that shows electric water, however it is  "Polystyrene" that holds a electrostatic charge inside the bottle and NOT the water. In a general sense it is a plastic capacitor with tap water an ion carrier..
Acca...
https://www.youtube.com/watch?v=l03ZQ9iiAUw[/font]
hi Acca,
I only wish someone can ask Ruslan in Russian forum on where to insert the nanosecond pulse.
Yes this will cut down on fact findings.
Hopefully by Christmas we are able to light some bulbs without battery. :)
At my end 2 circuit is available version 6.2 and version 7.0 nanosecond generator and another circuit which can be switched to do 1/60(60th Sub-harmonics) or 1/30(30th Sub-harmonics) frequency converter with shift control.Both circuits was posted recently.
I am merely waiting for some components to arrive to do final testing before creating a pcb board.
I recall someone ever mentioned about the capacitor needs to be charged before the device can be turned on to provide power to the bulbs.
Additional information the lowest possible nanosecond pulse achievable  using IGBT driver eg: TC4451 is 40 nanosecond and the other driver IXD is mere 38 nanoseconds.
From IGBT driver capability i doubt the nanosecond pulse on actual device is lower than 50 nanoseconds and surely below 300 nanoseconds.
Lastly i have attached photo of Ruslan device which i think is showing as 4KV to 6KV in Russian at the yoke 3 turns.
Hoppy
Quote from: TinselKoala on October 24, 2014, 09:05:20 AM
91.9FM
http://tunein.com/radio/TOPradio-919-s80808/
