0 Members and 75 Guests are viewing this topic.
Enjoykin
Ruslan did generator test especially for "famous" physicist 70 km away from town in wilderness. Physicist said  "our science is big lie" because Ruslan's device has disclosed all his illusions.
No more comments !!
MenofFather
Quote from: Jeg on October 24, 2014, 04:17:21 PM
Two things. Either katcher has a very low output, or needs synchronization. What is your opinion? I saw Ruslan's katcher, it doesn't seem stronger than mine. Katcher's signal is also a nice and clean unipolar pulse.
... my opion is that kacher frenquency must be same as bifilar inductor frenquency. But maybe that is wrong. Or maybe In Ruslan divice is strange synchronisation.
Hoppy
Quote from: MenofFather on October 24, 2014, 04:39:39 PM
I mean, that you can wound 0.8 mm wire on 5 cm diameter tube 9 cm lenght and that enought. Akula divice not have restangular wire, but it have tick wire also in oposite direction at endt, just for good holding ferite betwen antena and kacher secondary. You just must get 1.6 megaherc on kacher, you can wound almost with any wire from range 0.3-1 mm diameter. Only kacher frenquency must be something like 1.6 megaherc. Я уверен в этом.
Thanks for your well written explanation.
Void
Hi Jeg. That is something of a mystery still.
All the best...
itsu
Hey guys
I made a katcher driver, and fired my well balanced system for first time. By well balanced I mean it is tuned as to have a nice and clean sine wave peak at 2Mhz. It is a clean sinus without ripple even when I drive the line through square pulses. That means that it is tuned exactly on a frequency which is related to the exact wavelength. So far so good.
My katcher is tuned at 2Mhz with a coax cable as antenna shortcuted at the end as Dally's one. Katcher puts out not more than 2-3Kv. My bulbs didn't light more while firing. By measuring the voltage inside the grenade line while firing, I see a 2Mhz 20V peak to peak which comes from antenna. Almost nothing..
Hi Jeg,
sounds good, but i don't know about that "coax cable as antenna".
Could be its counter productive, have you tried measuring the voltage without it?
I would try to make a solid copper antenna from some 2.5mm² or better 6mm² solid copper wire.
Regards Itsu
