0 Members and 553 Guests are viewing this topic.
Enjoykin
Jeg try this
a) both bifilar windings wounded opposite each other.
b) ground that resonant capacitor between him and choke or ground point between choke and bifilar.
Hariec sync variant - in  fact this is exactly Akula sync between push-pull and Katcher.
Trick is - turn on Katcher in time than push-pull drivers are turning mosfets or simple turn on Katcher exactly on peak of sinusoid. X1 and X2 going at cathode of 1N5822 diodes and anode on outputs of mosfet drivers. Both drivers work in opposite phase.
IC2 is TC4428 differential type not 4426 inverting.
IC1 Pin 12,11,9, 6 connected
Decoupling of Katcher need be like at picture. Katcher (-) rail decoupled through high speed diode to ground. Use something like mur1660 or better.
You need very clean and sharp Unipolar Impulses at Katcher secondary output - like Ruslan shown on oscilloscope. Tune impulses with oscilloscope.
Reg.
Jeg
Quote from: Enjoykin on October 25, 2014, 01:24:34 PM
Jeg try this
Hariec synch variant  between push-pull and Katcher. Not checked on pcb !!
I have wounded more than 4 different forms of inductor including your proposal. I used all the possible wavelength combinations. The result is the same. Do you have a proposal to transfer radiant into the system more effectively? Something tested or something with theoretical support.
Enjoykin
Jeg3 variant - This was checked and made  by Akula with Tesla Transformers and he got 1.5kWatts OU.
Your Grenade is in fact HV capacitor. I thnk you need synchronization to get OU effect. Be sure to make bifilar choke between Katcher and antenna exactly like Akula and Ruslan did.
And try to record your ground response - because push-pull must work at some harmonic of Ground Frequency and Katcher need to pump Grenade exactly on same frequency. Connected on bifilar-choke and antenna.
If you did tests - tell me free resonant frequency of your Katcher at secondary. And frequency with connected choke and antenna !!
Hoppy
Quote from: Jeg on October 25, 2014, 01:40:50 PM
Jeg,
It might be important to establish a ground connection with an optimum length of wire. I will be using 16mm sq. If you look at Kapanadze's videos, his spark is pathetic looking for the green box device.
Enjoykin
Right Hoppy. What is most interesting for me is behaviour of grounding.
Grounding is totaly different than ground conductor is free in straight line instead going curled up in big bundle. Very strange thing has happend along conductor. Some sort of slowly gliding waves which affect compass. Try it.
In my opinions they are SOLITONS - scalar waves.
It is good everybody have several compasses for checking space around Katcher, bifilar choke, grenade, push-pull and grounding conductor !!
Did anybody heard for Tesla Magnetic diodes rectifying high voltage- high frequency currents to direct current ??
If somebody make experiments with Tesla Transformer(s) best output in function of inductor (primary) position is when inductor is exactrly 1/4  of Tesla secundary lenght above the ground. And don't forget dumping primary through two massive RF-chokes from HV power supply side.
Reg.
