0 Members and 571 Guests are viewing this topic.
John.K1
Hi MenofFather.
I c now. Ok. I have measured the inductance of my Tesla secondary around 2.7H. Not sure now ho high it is , but would be possible to use extra separate feedback coil with small inductance? To play with some small coil would be easier than to touch the Tesla coil which has already its resonant frequency set through the length of wire?
I think it is a matter of some pay trade. Smaller #of turns-smaller inductance ,less hassle with Katcher but smaller output   and   higher # of turns higher inductance but if it resonates right you get bigger output. I remember what Ruslan said- "watch the voltage "
Thanks.
magpwr
Quote from: Hoppy on October 26, 2014, 08:52:44 AM
Here is a few shots of my build so far. Still working on the coils.
hi Hoppy,
Nice layout.I see that you already got the Russian capacitors. :)
Mine is still somewhere along the way. :o
If i got the time later this week i will try placing a small toroid with few  turns of thick wire and one of the wire from the 3 turns (6mm sq) from my toroid will go through this toroid.
I will try applying nanosecond pulse via this small toroid and observe if i can obtain any nice pulse at the peak of the waveform for the low frequency.
If my theory works then we should see a knife cutting the waveform.Base on attachment the knife/nanosecond pulse(kv) is the line drawn in "red".
MenofFather
but would be possible to use extra separate feedback coil with small inductance?[/size] [/size][size=78%]
[/size]
[size=78%]Why you that need?[/size]
"To play with some small coil would be easier than to touch the Tesla coil which has already its resonant frequency set through the length of wire?[/size] "[/size]
Tesla coil not resonate on lengh of wire. It resonate on LC resonance.[/size]
Acca
 Here are links to technical book site, (russian, use translator) if any of you are not familiar with it.  Chapter 28 is the basis for the Ruslan device, he got his theory from these three chapters, that include Kapagen device.. Chapter 28 will give you the understanding on the principle of the coil saturation. It is VERY IMPORTANT, for the Ruslan device...
https://translate.google.com/translate?sl=ru&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fut27972.narod.ru%2FBook_2%2F28_Book_2_part_28.htm&edit-text=&act=url
http://ut27972.narod.ru/Book_2/28_Book_2_part_28.htm
http://ut27972.narod.ru/Book_2/00_Book_2_pril_42.gif
http://ut27972.narod.ru/Book_2/85_Book_2_part_85.htm
Acca...[/font]
d3x0r
Quote from: Jeg on October 26, 2014, 05:51:03 AM
Meow, your point of looking things is always welcomed! :) I like this theory of substituting cap with pair of coils. Do you know any Tesla patent that describes exactly this behavior of a couple of coils under this high voltage pressure? Any else's theory or idea which utilizes two coils forming a capacitor? As far as I know is that when signal crosses zero, coil behaves as a capacitor plate. But I can't see any reference or similar tests and experiments..
Welcome aboard John, and thanks for informing us about ruslan's way of calculations. Good luck on your Ruslan journey.
Nice work itsu, very elegant and careful. I see that even you transmit in low frequency, your output is weak. In my 3055 circuit I consume 1A and I have lower bias resistances like 1000 and 50 Ohm to raise the voltage output. But again I am not very happy. I can't trap the right amounts of the transmitted energy. I obviously miss something.
Mag, nice work and skills. It was time to make your grenade. Good luck with your build
Void, nice to see you building this at last. We need your parallel input and observation to all of this.
Good day people
Thomas Trawoger pyramid power
https://www.youtube.com/watch?v=-7GYlo-6Kng
Uses coils wound in parallel as a capacitive component... having built the coils and caps and measured them, puts the unit smack in the middle of AM radio range.
Behavior?  As a capacitor... Probably because of the mututal inductance... how they are wound improves capacitive effects...
tuning of some Ghz systems was a capacitor made of two short (1") peices of wire twisted together... to adjust the capacitance you'd twist the wires tighter or looser (ancient military radar, folk story)
hans coler or something?  he had an ajustiable capacitor that was two coils wound to slide within each other... good for a few pF of capacitance...
