0 Members and 781 Guests are viewing this topic.
d3x0r
Quote from: John.K1 on October 26, 2014, 08:19:16 AM
Menofather. Why can't you get the same frequency  with longer coil ?? :) full wave, 1/2, 1/4 or multiplies of resonant frequency still can vibrate on the same given frequency :) Let's say his tuning frequency was 3.3 MHz (that's what he showed in the movie)  , He use 0.8mm wire. His tube is D50.  The length of wire to tune to get that natural frequency would be 300/3.3MHz  = ±91 m.  One turn takes 3.1415*50=0.157m. From that 91m/0.157m=579.62 turns. He Use plastic insulated wire - it means the pitch would be like 1.6mm.  So, in his case full wave resonator should be long around as 579.62*1.6= 927mm. He shows just around 11-12 cm. It wouldn't be even 1/4 wave. I  am confused from that. In any case I wound 1/2 wave resonator with magnet wire and I separate them with sawing thread and the varnish on top.
Thanks.
Because as a coil it's not just a length of wire, it has increased inductance which decreases frequency (increases inductive reactance at a given frequency)... that and a longer wire ends up with more inherent-capacitance, which also decreases the frequency.
NickZ
  Hoppy:
  Wow, your set up looks real nice...  I hope that it works as well as it looks.
  Since I couldn't just sit on the bench and watch what you guys are up to, I decided to replace my smoked IRFP260N fets with two smaller ones that I had on hand. The IRF630B, and also a IRF634B. And, my circuit lit up, once again...
BUT, what a difference, as I can only light a single 50 watt bulb, instead of 5 to 7 100w bulbs. Everything else being the same as before. This is without any tuning caps placed, yet.
  I also got my Kacher working again, so, I'll continue on with connecting it all together, to the induction circuit.
  At this point anything is better than sitting on the bench.
a.king21
d3xor:  Re Trawoger:  I followed him a few years ago. There is a Trawoger thread on this site, He turned out to be an absolute faker and investment scammer.
Re Kapanadze:
I can confirm that he told me he had to measure his wires.
When I asked him about upgrading his device to 500 kwatts/hr he said it was no problem, he simply had to measure his wires.
When I asked him about putting his device inside a cfl bulb he said there would be no room for his bifilar coils.
Hope this helps.
MenofFather
Quote from: a.king21 on October 26, 2014, 11:54:58 AM
Hope this helps.
Interesting, Kapanadze use indutive or not inductive bifilar coils?
Hoppy
Quote from: NickZ on October 26, 2014, 11:54:44 AM
  Hoppy:
So do I Nick!  ;) Thanks. However, if none of us can get it working, then that's a significant also.
