0 Members and 139 Guests are viewing this topic.
Void
Quote from: MenofFather on October 27, 2014, 06:35:24 AM
In you video is not bifilar. Ruslan say how need wound inductor. First wound normal, then wire must go to other and and on this wire wound need second layer.
Hi MenofFather. T-1000 translated that Ruslan said this coil is wound like Leedskalnin's PMH coils.
If that is correct then you wind the first layer of the coil from one end to the other end, then
continue winding from that end back towards the first end, and still winding in the same direction. Just like
the first two layers of the grenade are wound for example.
All the best...
Void
To summarize the issue with determining the tesla coil frequency, Ruslan has stated
several times (as I understand it) that the frequency of the tesla coil is not dependent on any 'LC resonances'
that the grenade coil may have, that it is based on the grenade coil wire length. Now here
is the problem. If the above statement is true, then the frequency of the tesla coil should
be some exact multiple or sub multiple of 2MHz, 4MHz, or 8 MHz (depending
whether you take the grenade coil as a quarter wave, half wave, or full wave).
Certainly 1.5 MHz to 1.6 MHz does not divide as a whole number into any of those
frequencies, nor is it 1/3 of any of those frequencies. What Ruslan has been saying
is just not consistent with the actual frequency he says he is tuning the tesla coil to and with the
grenade coil wire length Ruslan said he has been using (37.5m for the 12V device, not sure for the 24V device).
It is not related to the tesla coil being resonant at say 2 MHz unloaded, and a lower frequency
when loaded, as that is not what Ruslan has been saying at all. Ruslan has said (or at least implied)
the operating frequency that the tesla coil is tuned to is dependent on the grenade coil wire length.
A tesla coil operating frequency of 1.5MHz to 1.6 MHz does not have any obvious relationship to a
grenade coil wire length of 37.5m that I can see. Something is just wrong there.
All the best...
John.K1
Not sure why are we discussion the "grenade coil" as it is perfectly shown and described  on his video "how to make a coil" . Ok, maybe pain in an ars for non Russian speaking- let me make it  clear for you.
He is not "turns" oriented - he only measure the length of wire which fitted to his roughly 21 cm length.
You wind the first layer and back the second layer. After you move to the halfe and wind third layer in OPPOSITE DIRECTION and 4th layer back. You move than to halfe of halff (actually 1/4)  and continue two more layers  the same  like previous one.  After he just went with the wire shorted way  to the tube and out.  He noted what lenght he used and calculated the 14/4 wave frequency and tune the Tesla to that frequency.  On the first layer he  wind the inductor which is exact half of length of the wire of the grenade coil. I think it was in opposite direction with respect to the first two layers, but it is not as much important.  The total inductance of all coil should be low - he measured his around 0.25mH.   Today I watched some more his final video where he clearly state his Tesla has at the end (between tesla and grenade coil) some turns OPPOSITE direction than Tesla is wound. He also says the best result he is getting with his system around 1.8 MHz.   I didn't get to such details during my build yet. I am trying get my katcher to my 1.87 MHz now :)
For Russian speaking or understunding- there will be open discussion on the skype  in 2.11.2014 at 15.00 of Moscow time. More info here: http://realstrannik.com/forum/freeenergylt-antanas/48-ruslana-kulabukhova-audio-konferentsii.html#1325
Void
Quote from: John.K1 on October 27, 2014, 07:09:10 AM
Hi John. You have completely missed the point on both topics being discussed above. ;)
There was no questions raised about how to wind the grenade coil above.
Yes, there are also different translations of Ruslan's tesla coil frequencies being both 1.5 MHz to 1.6 MHz,
and 1.8 MHz being posted here as well.   ;D
All the best...
T-1000
Quote from: Void on October 27, 2014, 06:40:53 AM
All the best...
The "Leedskalnin PMH" was my comment and the winding direction is always beginning from same end which means 1 layer until end then 1 turn to beginning and next layer on top from same end as first layer...
